1991 Legacy rear brake rubbing?
10wrxing
Post by 10wrxing »
Ok so I'm done the rear brakes on the Legacy. New rotors and pads. Now when I make turns (mostly does it on right turns), it sounds as if the caliper bracket is touching the rotor.
I have had it apart a few times this morning and I can't see anything wrong.
The rotors spin freely when the car is up in the air.
I'm wondering if it's a wheel bearing starting to go?
But it didn't do this before touching the brakes.
Thanks in advance guys.
killajamal
Re: 1991 Legacy rear brake rubbing?
Post by killajamal »
Check to see if you bent the heat shield. I've done this on accident. It makes a nasty metal on metal sound on hard turns.
10wrxing
Post by 10wrxing »
Thanks, I'll check that when I get a chance.
killajamal
Yea lemme know. I'm curious!
10wrxing
Post by 10wrxing »
Ended up being the backing plates.
Too much rust and was touching the rotor.
Grinded them down and all good now.
killajamal
Right on. Those heat shield things behind the rotor right?
10wrxing
Post by 10wrxing »
Yes.
Still seems to be rubbing sometimes, but I'll live with it.
