Compressor Specifications:
Compressor Wheel Blades: 6+6
Compressor Wheel Inducer: 52.5mm
Compressor Wheel Exducer: 70.0mm
Does anybody know of a good source? This is in an IHI type housing, and so the shaft is IHI.
It was said that the compressor wheel originally belonged to a GM diesel turbo.
Deadbolt and Kingpin Performance used to modify VF22's by fitting this wheel to the CHRA and boring out the compressor housing to fit it. I have one of these, but it is in rough shape. The PE1818 I have looks to be in good shape other than a few bent fins.
Trying to find a source for a PE1818 compressor wheel
