jessmans rio red 91 SS EJ20g swap lots of pics
Re: jessmans rio red 91 SS EJ20g swap lots of pics
Thanks for clearing that up for me, Well you win some you lose some i guess........ On another note i got it to fire up first try! and everything is in good order mechanically its a very healthy motor im having some issues with things not being properly connected and some vacuum line differences from the diagram anyways check out the video im very happy to have gotten this far on my own but i definatley need help and good advice on the rest of the stuff i need to do check it out click the image below
88 Honda civic wagon B20VTEC SWAP-RIP
85 Subaru loyal sedan-SOLD
95 Subaru impreza $500 BEATER-SOLD
91 Subaru legacy SS jdm ej20g swap
CHECK OUT MY ej20G BUILD HERE>> viewtopic.php?f=25&t=53766
So in the video the car was running great first start and did have any (CEL's) one i first drove it it ran very poorly lots of hesitation and an extremely poor and crazy idle once warmed up and would not build boost im figuring i have a few things/ maybe a few vacuum lines hooked up incorrectly it is drivable ish i drove it a few miles to work for a few days babying celebrating the work iv done thus far but i have now parked the car and am re tearing in to it i pulled the codes from the ecu !!
#22 Knock sensor
#24 Air control valve
#32 Oxygen sensor
#35 Canister purge solenoid valve
#44 Duty solenoid valve (Waste gate control)
and these two listed as the same code??
#45 Atmospheric pressure sensor
#45 Pressure sensor and pressure exchange solenoid valve
Now iv already eliminated the 02 code it wasn't fully plugged in and i changed out the knock sensor for my ej22t one that worked no change any ideas guys would not having the vacuum lines properly hooked up cause most of these issues iv stumped
#22 Knock sensor
#32 Oxygen sensor
i do know this is the Canister purge solenoid valve which is the cause of one of my fault codes it worked fine before my swap just not sure whats up here?
i also made sure my grounds where good i am i supposed to have the harness ground on the manifold or somewhere else im wondering??
harness ground
manifold ground
block ground
harness ground
manifold ground
block ground
To me, it sounds more like the coolant temperature sensor - the one that feeds the computer, not the gauge.
Would you suggest i change it out do those really go bad?
They do go bad. They run about $15-$20 on Rockauto.com. On these cars, I don't trust codes much.
If you can read the ECU parameters, you can test by watching the reported engine temp. It should rise as the motor warms up. Check out this (http://www.vwrx.com/index.php?pg=selectmonitor) and this (http://www.alcyone.org.uk/ssm/sma.html)
I find that once you set yourself up to read parameters directly from the ECU, troubleshooting for most everything is much faster. However, in the FSM there is also a method for testing almost every sensor with just a multimeter.
Running well when cold, but progressively worse as the motor warms up is an indicator that the ECU 'doesn't know' the car is warming up and is still in it's 'choke' routine.
Nice build! You'll get it all figured out sooner or later. Planning on doing any ECU mods to unlock all that sweet EJ20G power?
The SS 5MT transmission will be fine if you treat it nice. I had a TD05/18psi EJ22T with a stock 250,000 mile SS trans and never broke it. It's all about smoothly shifting and releasing the clutch before applying power when shifting and never launching it.
Just thought you might like to know that your wheels aren't actually WRX wheels, they are 4th gen Legacy GT wheels.
I know what you mean lol well while my intake manifolds off ill make sure swap my ej22t one on well see if anything changes i belive most of my problems are coming from the iac valve ??PhyrraM wrote:They do go bad. They run about $15-$20 on Rockauto.com. On these cars, I don't trust codes much.
Alphius wrote:Nice build!
Thanks man i love this older platform its my first turbocharged car i know what you mean about the transmissions one i first got this car stock i launched it racing my friends 2.5 RS and grenades the trans i have a newer one and definatley don't wanna go through that again no launches no donuts to banging gears im gonna baby it grandma shift and enjoy the car ill leave banging gears to a Honda lol i figured the wheel thing out a while ago they cam off my friends wrx i kind of like them more anyways id really like to find a set of RS wheels mmmhhhh
heirs another video of how its been before i pulled it apart please excuse my terrible commentary... take a look at how my vacuum lines are
After that video i drove it to work one more night and parked it and pulled the manifold off and am starting the check the wiring harness and affected sensors
checking the iac plug
i was wondering this having a jecs IAC could it not be working with my Hitachi ecu ?
i also removed the ecu to take a look at the wiring dont know why people fuss about this it was a piece of cake
also i may have found why my knock sensor is throwing a code its got this weird wire sheilded?? that's been cut and twisted together in two places covered with blue tape sorry for the crappy pics but as you can see..............
It was a little hard to follow the vacuum lines during the video. If you can draw out something in MS Paint that would be helpful.
It's fine that you have a JECS IAC and a hitachi ECU.
The knock sensor produces a very low voltage signal and to keep electro magnetic interference (EMF) from screwing up the signal there is that wire mesh (shield wire) around the signal wire. It's hard to see in the picture how they have that jumpered. Ultimately as long as that wire mesh is properly hooked up to the ECU it should be ok. Most of your EMF will occur in the engine bay, so if the shield is unwrapped, as long as it's still connected it should be ok.
I would recommend checking the resistance of the knock sensor wire from the ECU connector to the connector in the engine bay.
Alright ill check that i swapped my other coolant temp sensor on also!!! actually waiting on a better quality multimeter to arrive in the mail in the mean time i got a few things done got the intake manifold painted something iv always wanted to do i reinstalled everything and have it almost all back together with new intake manifold gaskets still waiting on a new down pipe gasket i ordered as well
and after a few day or so to dry not to shabby
getting everything reinstalled
got some new intake manifold gaskets as well ej25d gaskets where a perfect match ej20g on the top ej25d on the bottom
manifold back on
so after laying my inter cooler back on i noticed my new hks ssqv isn't gonna work as it is making contact with my iac looks like im going back to the factory setup somhow its crazy how dirty a car gets one their parked for a while geez
manifold back on
Legacy777 wrote:I would recommend checking the resistance of the knock sensor wire from the ECU connector to the connector in the engine bay.
I was wondering how i do this the leads on my multimeter are very short and would not be able to reach from plug to plug just wondering ?
I like the fact your garbage can is your paint stand
Regarding the multi-meter test leads. I just use an extra piece of longer wiring connected to one of the test leads. I then will shove that wire in the connector for the knock sensor and then use the other lead on the ECU connector.
nice that's kind of what i was thinking but i figured id ask ill give it a try and report back my findings and yeah lol iv used that garbage can for alot of stuff mostly laying parts on it to clean and stand up lol doing what i can with what iv got
back at it so i hooked my multimeter up to the knock sensor everything seems ok wiring is ghetto tho found out it was hard wired straight off the ecu already..................
and that the plug was all shitty the wire was merly twisted together under the dash
so for this wire being shielded i need to go off of eatch of these pins one i go to rewire it? my question is whether or not the shield portion of the wire needs to be grounded the signal goes to the plug hopefully im explaining match the colors!!!!!! just wanna make sure i have this right before i try and rewire it !!!!!!!!
SO for a while i had thought my down pipe gasket had been leaking so i go to replace it with a thick grimm speed gasket i just got in the mail turns out after removing the down pipe its cracked like a mofo .........dam it im going to try and get this re welded soon!!!!!!
ha mutch thicker
damit
ha mutch thicker
damit
You just want to connect the shield wire to pin B56.4. You do not want to ground it.
Right i was talking about the plug end where it goes in to the knock sensor do i just tape it up around the signal wire and call it good?
Well i have a small side update i got my down pipe back had a good friend re weld it up hopefully it holds im planning on cleaning it up and spraying some type of coating on it before i re wrap it
Yes, you just wrap the shielding up with tape.jessman1942 wrote:Right i was talking about the plug end where it goes in to the knock sensor do i just tape it up around the signal wire and call it good?
Dang its been over a year and i still haven't gotten my car running right. Im back at it tho and will be taking pics and asking a lot more questions. Im picking this thread up from the dead this dam car will run!! Got my full rob tune 550 setup to boot more to come.
