Have tried shifter sequence to reset the ecu but was going to try pulling fuse 16 out.... Which one is it, picture of my foot well fuse box cover. cheers
Import legacy fuse box picture - 16(EGI/TCU) under the dash?
These should be "similar"
http://www.main.experiencetherave.com:8 ... ns/118.jpg
http://www.main.experiencetherave.com:8 ... ns/119.jpg
You can verify them by checking the amp rating.
It should be fuse 14....not fuse 16.
It's the far right one on the second row in your pic. It's 10 amp, and says EGI AT on it.
