Service parts available...
Matt Monson
Post by Matt Monson »
I just wanted to put out there some of the many spares that I have for folks that might need some things to do repairs on their engines, etc. Most of these parts have 50-60k on them and come from EJ20G's but they are the same as Ej22 parts. Some are from EJ22's and have slightly higher mileage. And some are from Ej25. Those all jave 10k mi or less. If you post or PM me specify turbo or NA, as I have both. All prices are shipped ground in the lower 48. Add $10 if you are in Canada
Oil Pumps. $40, retail is $140. I have 3-4 of these, turbo and NA
Alternators $40, retail is $200, I 4-5 of these
Water pumps. $35 retail is $100. I have 4-5 of these, turbo and NA
Auto Starter $50, retail is $200. Just the one
A/C compressors. $50, retail is $500. I have 5 of these. I would need manufacturer and part number to correctly match yours. I also have several complete AC systems
Various sensors (crank, cam, coolant, oil, etc.) $20 each. And NO, I do not have an IAC's. Sold all of those
Timing Belt Pulley sets. $50 a set or $15 each. These retail for $65-85 each.
HLA's. $10 each. Don't know retail
Intake Manifolds. $40 each. It's the freight that jacks the price here.
I've got lots of other stuff from engines. If there is that missing bolt or timing belt cover or whatever you need like intake plumbing, fuel rails, breather hoses, go ahead and ask. I've probably got it for you.
I can be a little slow to find out if it's in my garage and get it out to you, but if you ask around you will find I always deliver and in the condition promised. NO PICTURES. I don't own a digital camera, and if you don't know what an alternator or this other stuff looks like I can't be of much help to you. These are really standard items, not like a set of STI heads that you would want to "inspect" and view. Thanks for shopping...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Post by 555BCTurbo »
I'm interested in an HLA if it is new...
Bheinen74
Post by Bheinen74 »
knock sensor turbo?
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Matt Monson
Nick,
These are all good used parts.
Brent,
I should have one of those. Let me check the box of sensors tonight...
Suby Hai!
Matt Monson
bump to keep it visible...
Suby Hai!
Matt Monson
doh,
forgot to look for the sensor. I will try this one again...
Suby Hai!
MikeC5
Post by MikeC5 »
I'm looking for an under engine tray for a 95 Legacy.
Matt Monson
What's an under engine tray?
Suby Hai!
MikeC5
Post by MikeC5 »
It's usually a plastic shield-like thing that shelters the bottom of the engine compartment from snow/water splashing up in. It is typically held on with a few bolts and or re-usable plastic fasteners.
I think they tend to get 'forgotten' when people bring thier cars to Quickielube-type places....
Matt Monson
nope, don't have one. You'll have a hard time finding the correct one here. Your '95 is a different chassis than all of our 90-94 members...
Suby Hai!
Post by BAC5.2 »
Matt - I have a NEW IAC ;)
0perose
Post by 0perose »
I should really get an oil pump, water pump, and starter for auto... all for the same N/A ej22
does shipping come down if I buy lots of stuff? :D
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
Matt Monson
Absolutely,
UPS charges like a baseline freight and then they scale it accordingly. What's your zip code? I'll give you an idea of what freight will be...
Suby Hai!
0perose
Post by 0perose »
Matt Monson wrote:Absolutely,
13697 and I guess I need to put some money in the bank because my starter is dying quick. got paypal?
Matt Monson
Freight should be $20 or less. Shoot me a PM with your pp addy and I'll send you an invoice...
Suby Hai!
Natoe
Post by Natoe »
happen to have a throttle position sensor for a turbo?
thanks
Matt Monson
How about I just send you a complete throttle body?
Suby Hai!
Natoe
Post by Natoe »
how much would you like for that?
i wouldnt just trade TB's on my car because mine is modified so all i need is the TPS... but as long as its easy enough to remove.
Natoe
Post by Natoe »
any idea....? just need a tps
Bheinen74
Post by Bheinen74 »
bump for knock sensor, only if it is good. I was going to get one from blackbart, but his ended up being cracked on the outside.
Paypal?
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
gt2.5turbo
Post by gt2.5turbo »
you wouldnt have to have everything for an hydraulic clutch setup would you?
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
petridish38
Post by petridish38 »
I might be interested in the t-belt pulley set as long as they rotate without any noise or anything... and if they have less than 10k miles on them, then i would assume that they are fine...
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
Matt Monson
gt2.5turbo wrote:you wouldnt have to have everything for an hydraulic clutch setup would you?
I've got a slave cylinder and throwout fork from an RS. Depends on if you need push or pull type..
Suby Hai!
Matt Monson
petridish38 wrote:I might be interested in the t-belt pulley set as long as they rotate without any noise or anything... and if they have less than 10k miles on them, then i would assume that they are fine...
Andrew
None of them have less than 10k on them. They have just been tested by hand. If they hang up at all, I toss them.
And for everyone, I kind of forgot about this thread. So if you need something, give me a heads up with a PM. Then I don't leave questions sitting here for a week... :o
Suby Hai!
petridish38
Matt Monson wrote:None of them have less than 10k on them.
Crap! I think I was reading too fast and just read the 10K part lol...
Andrew
209,000 miles!
