WTB 91 Legacy Parts
Anshii
WTB 91 Legacy Parts
Post by Anshii »
Hi guys, I'm looking for a couple parts for my 91 Legacy. I know I need a rear axle as well as some CV Joints...
Anyone parting out anywhere near Seattle?
polychrome
Buy rebuilt parts...
Post by polychrome »
The CV joints are in the prop shafts (half shafts, half axles). If you have AWD (4WD) then you have 4 of these and no other axles. Rebuilds are about $40 or $50 each at Auto Zone or Advanced etc. after you turn in the dead ones. If you've done it before the job takes 45 minutes per axle, but 3 times that the first time. Its too much work to play around with junkyard parts.
Anshii
Post by Anshii »
My car is AWD.. sorry I'm not so knowledgable about cars. :( I'll see if that is plausible.. cause I'm not the one doing the work.. although I wish I was.
Anyone have legacy emblems/bagdes? And a driver side visor?
bepa
Post by bepa »
you may not start out doing your own work but you will learn and start soon after. subaru are fun to drive, quick if you have a stick, turbo or a newer model. from what I am reading the 2.5 needs looking after for longer life. look around the site a little and you will read about a couple of yards out your way. I'm in new york yet I have read about 2 good ones if what is said is ture. read around and you will find a few names. good hunting, good learning and be well.
Manarius
Post by Manarius »
Ok, you have AWD. If you need rear half-shafts, get them from autozone for like $55 for lifetime warranty ones. It takes about 45 minutes to do one.
As for badges and driver's side visor: Blackbart has a lot of that stuff, but you may need to do a junkyard run.
