used to get 24-28 mpg with my 94 touring wagon, that was for about a year and a half, prior to this past winter.
this winter, I can't manage any better than 17mpg
Yesterday, i was checking under the hood routing maintenance, oil check, coolant, washer fluid, brake, etc etc.
GUESS WHAT I FOUND?
turbo outlet hose clamp loose......
hopefully my mileage will get much better now........lol
and now its almost time to park it until next winter, and get the summer car out......
lose hose clamp off turbo outlet and bad mpg
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
That's pretty bad. Mine did almost that well when I only had spark in 2 cylinders, so the other two cylinders were just dumping gas out the exhaust pipe.TheSubaruJunkie wrote:the best ive ever seen was 16mpg... my average is 13.5mpg.
-Brian
'00 Impr RS - sold
I get 200mi per tank, maybe 210mi before the gas light comes on. I put new plugs in the car when i bought it, and it runs on all 4 cyl's, but im thinking maybe its due for new plug wires.
Not sure where else to look, I put a new O2 sensor in a couple weeks ago, but that only brought my MPG from 190mi to 200 per tank.
-Brian
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
1986 Toyota 4Runner
