It's been over 70k since my timing belt was last replaced. What should I expect to pay for the job (labor rate is usually $70 in my area).
Thanks.
Timing Belt Replacement-How Much?
'06 Impreza 2.5i wagon
Uh, why don't you just replace it yourself? It's really not difficult, even for folks who are not the most mechanically inclined. There's more than enough information on the subject on this site. I say screw paying somebody else to do your labor; even licensed Subaru mechanics screw up sometimes. You could probably do it yourself in a couple hours, then all you would have to pay for is the $40 timing belt (I don't know where some people on this website buy their parts, but I've heard people say they paid $80 for a new belt. This is ridiculous. If you shop around just a little, you should never have to pay more than $40. I got mine at Auto Zone for $38. Even an OEM belt from the dealer only costs $55).
All you need for the job is a 10mm end wrench, a 12mm end wrench (or socket), a 14mm end wrench, and a 22mm socket with a breaker bar (for busting loose the crank shaft pulley bolt), and a vice or C-clamp (for compressing the tensioner). If you have these tools, a guide of some kind (Chiltons, Haynes, etc.), and a couple hours of free time, you can pull this job off yourself really easily and save yourself hundreds of dollars.
92 LEGACY EJ22 WAGON
Yeah, its not bad. I did mine over the course of a couple days (including water pump) after work (2 hours ish each day)
The only gotcha is if you have a DOHC motor (you didnt specify your vehicle), its a little more fiddly to prevent valve damage. But on the SOHC motor, you have to try really hard to screw it up.
