Fuel Pump went out I'm guessing, but could it be a fuse?
Well as the title says, pretty sure my fuel pump quit on me yesterday on my 92 ej22t sedan but is there a fuse for the pump that could have messed it up? and if so where is it located? thanks
92 legacy AWD ej22t 5 speed, rebuilt internals, custom intake, custom 2.5in catback, running 11psi, sti shocks and struts..
Re: Fuel Pump went out I'm guessing, but could it be a fuse?
Could be a relay but there is no fuse for the fuel pump. Pump probably died though as these cars are very old and generally have a lot of miles.
There's also the connector under the back seat that goes bad. Another board member just had this issue: http://bbs.legacycentral.org/viewtopic.php?f=19&t=49622
Everythings running good now..got it all sorted out..thanks everone for the replies
So, was it the connector under the rear seat that was the problem or was it something else?
'94 TW
