engine rebuild to pass the inspection with a bad turbo on it
Posted: Fri May 23, 2014 6:43 pm
yea i manage to get a legacy 1992 in good condition beside the turbo and engine need some gasket job which i had since i was about to rebuil my 94 which as got in fire
the problem is i buy that car from toronto and i dint pass the inspection not immatricualtion either i bring it back to quebec but now i need to fix it so i can pass the quebec inspection whic is going to be emission and general mecanic
the problem is the turbo dont spool at all seem like something is going wring i can see a lot of clunk all around the wastegate, so if i wanna change the turbo i would love to go a bit bigger but i guess if its that case i wont pass the emission????
so i am shoppping around and try to get advise from guru from this web site
i have a lot a brand new part which may help to make the car look more decent but i definitly need to fix the brake and see what can be done to pass the emission test
anyone know what need to be done, cant really ubgrade it with modification before having the inspection!
