Knock problems
Posted: Tue Sep 02, 2014 5:57 pm
by lucas
Hey guys i tried using the search to remedy a problem I'm having with my wifes car. Its a 93 turbo sedan auto, it was in poor running condition when she bought it. when we got it, it was showing like 8 codes and by process of just fixing things i narrowed it down to two codes. A cam sensor and a knock sensor, I had a old spare cam sensor fixed that no problem.
I then changed the knock sensor with a new one from oreillys lasted maybe 2 months then the CEL began to randomly flash for a few seconds then disappear. It seems to happen more frequently at a stop. I put a new sensor on there same brand did the super computer reset and the problem went away for 1 day then came back.
The car does not run poorly but the constant knock cel concerns me. When i changed it this last time i noticed that some of the plastic wire shielding had been pulled away from the Plug end of the knock sensor from the harness end. I don think a tiny bit of exposed copper would cause that big pf a problem but maybe I'm wrong?
Any help is always appreciated!!!!
thanks, Lucas.
Re: Knock problems
Posted: Wed Sep 03, 2014 3:27 pm
by cj91legss
You can check the resistance between the plug and the ecu. That'll tell you if you should think about running a new wire to the knock sensor. With a little bit of wire exposed, I'm wondering if it's grounding out from all of the movement and triggering a cel.
Re: Knock problems
Posted: Wed Sep 03, 2014 4:59 pm
by lucas
thats what I'm thinking. I might try cutting the bad end off and getting a new one front the junk yard.
Re: Knock problems
Posted: Thu Sep 04, 2014 5:42 pm
Based on my experience that knock sensor wire can be very brittle and there may be cracks that are intermittently connecting/disconnecting causing your problems. I would do what CJ suggested and check the resistance of wire from the plug in the engine bay to the ECU. I'd suggest moving the wire around to see if resistance or conductivity changes.
If you need to replace it, the cheapest and probably best option is to use some shielded microphone cable from radio shack.
Re: Knock problems
Posted: Thu Sep 04, 2014 8:27 pm
by lucas
I've never ran a new wire like that before but I'm sure the car being as old as it is probably needs a new one. Doing something like that isn't very hard id imagine.
Re: Knock problems
Posted: Thu Sep 04, 2014 9:17 pm
by cj91legss
it's not hard at all. When I ran my new wires, I used the hole under the brake booster. On an N/A legacy, this hole is where the clutch cable would go thru the firewall. On a turbo car there's just a rubber plug there.
Re: Knock problems
Posted: Thu Sep 04, 2014 11:39 pm
by lucas
word right on, thanks guys
Re: Knock problems
Posted: Thu Sep 04, 2014 11:43 pm
by cj91legss
No problem.
Re: Knock problems
Posted: Fri Sep 19, 2014 12:52 am
by Mister Anderson
Yesterday I replaced my cam, crank, and knock sensor wiring. Make sure you solder the connections and if you can, shrink wrap everything. Harbor Freight sells rolls of shrink wrap and also heat guns for cheap. I picked up some shielded 3 wire at Home Depot for around 40ish cents a foot. The last 3 tubro legs I have worked on all had brittle sensor wire, so it might just be a good idea to replace it anyway.
Re: Knock problems
Posted: Sat Sep 20, 2014 7:32 pm
by lucas
I dont solder things because I've had them break apart. but i do by those nice buttsplices and heat shrink everything. Its still jacked up even though i put a new connector from the harness end on. Still randomly throws knock code it needs a new wire completely and i still have no idea how to do that. Might pay someone to do it.
Re: Knock problems
Posted: Sat Sep 20, 2014 7:59 pm
by cj91legss
Did you already buy mic wire and connectors?
