ej20 with ej22t heads
Well my spare ej22 is scrap.....i have a ej20 wrx usdm block. Will it work with my ej22t heads?
Re: ej20 with ej22t heads
Yes it will. Its the combo I put in a 91 I sold a year or so ago.
If you happen to need a set of 2.0 head gaskets, I have some for sale in my post in the parts shed.
how did it turn out? did you have to use the 2.0 head gaskets?cj91legss wrote:Yes it will. Its the combo I put in a 91 I sold a year or so ago.
It ran great. I used the 22t gasket. I should have used the 205 gasket because of the difference in cylinder size and the fire ring. But it ran fine.
Ended up selling the car, to my knowledge the guy still has it.
Yes, you really should match the head gasket to the cylinder bore. Also make sure the combustion chamber won't at any point be larger than the bore.
ok thanks. i think the 2.0 gaskets/bore will match the ej22t heads wellAlphius wrote:Yes, you really should match the head gasket to the cylinder bore. Also make sure the combustion chamber won't at any point be larger than the bore.
So the 2.o wrx gaskets are a perfect fit.....but.... block 2 little square hole tot and center of the combustion chambers and also two very small holes near the bottom outside edge. Anything to worry about?? They seem to be a better fit and line up much better than the aftermarket 22t head gaskets
Show us an image.
I have a question
EJ22 SOHC block with EJ20G DOHC heads - this setup will be work ??
Wysłane z iPhone za pomocą Tapatalk
I think this will net an even higher compression ratio than my setup. I'm already just over 9. If you could massage and cc the combustion chambers possibly? I'm sure its been donekaszlarz wrote:I have a question
Nice!!!
n/a or turbo block?? iv been looking into this aswell i have late g heads off an sf5 forester. and a 22t legacy that im doing this same thing.. i was told with 20g heads on a 22t it would be around 7.7:1 with stock thickness gaskets
91 legacy wagon 22 na
93 legacy wagon eg33 swap under way
