Td04 setup into a stock 1991 Subaru legacy turbo
I am wondering what do I need in order to set my car up with a td04 and tmic into my stock ej22t 91 legacy turbo?
- Winestone Cowboy
Re: Td04 setup into a stock 1991 Subaru legacy turbo
There's tons of threads on here u can go through to see everything u need. Do a little searching
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
I'm new to legacy central I apologize
- Winestone Cowboy
No problem, just a heads up
Hi and welcome to the forum! Check out the first thread in each section. In this section there's a good thread up top about an 07 wrx intercooler with a td05. Your td04 follows almost all the same steps. The major difference is you'll need to buy a silicone 90* elbow to connect to the factory intake tract.
