Clocking a VF11?
wtdash
Clocking a VF11?
Post by wtdash »
Anyone clocked the center - CHRA - of their VF11 to mount it 'upside down' for another application?
I've read you must keep the oil INLET on top and OUTLET (drain) on bottom but what about clocking the Compressor and Turbine to allow it to mount to the exhaust manifold from the top vs. the bottom?
Can I just loosen/remove the bolts circled in blue?
If you must know this is going on a Zetec DOHC 2.0 - inline 4... :-)
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: Clocking a VF11?
You can disassemble the turbo so just the center portion is there. It would need to be reassembled and balanced by a shop if you were to use it again.
Here are some pictures of my disassembled vf11
https://www.main.experiencetherave.com/ ... s/ej22t/15
https://www.main.experiencetherave.com/ ... s/ej22t/27
wtdash
Post by wtdash »
Thanks as always, Josh.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
You're welcome!
