Page 4 of 5
Posted: Thu Apr 21, 2005 5:38 am
by THAWA
The twin scroll turbo? No, none in the us. We don't have a version 8 or 9 sti, nor do we have a 2.0GT
Posted: Tue Apr 26, 2005 3:01 am
Anyone know the part # for the little black triangle thingy that covers the screws to attach the mirror?
i can't find it in my parts book.
Posted: Tue Apr 26, 2005 4:11 am
found them
These are for the black ones. Blue ones are a different part #
94067AA000VG
94067AA010VG
Posted: Sun May 15, 2005 2:41 pm
by EJ22_SLO
A friend found Subaru Fast - electronic part catalog for Subaru...
ZIP file, 275MB
I installed it, but i cannot get it running; i use WinXP pro,... any ideas how to solve this?
Posted: Mon May 16, 2005 12:03 am
I'll take a look at it, and see what's up.
Posted: Mon May 16, 2005 6:40 pm
Well you have to use the clone cd program to burn it to a disc....then you load the program.....however I have not gotten it to work. It keeps giving me a buffer memory error that there's isn't enough memory.
So I don't know. I've tried it on two computers. It looks like this program is setup to run on windows 95, 98, ME....I got an error during install on my 2k machine.
Posted: Tue May 17, 2005 5:53 am
by EJ22_SLO
I have same problems. But - I just got an idea (6.50 AM here
) - using Windows98 boot disk i get "pure DOS" ; it yould work; will try in the evening.
Posted: Tue May 17, 2005 9:52 pm
let us know how things work out.
Posted: Tue May 17, 2005 10:23 pm
by EJ22_SLO
doesn't work in pure DOS... looks like it needs DOS based Windows (95, 98/SE, Millenium) afterall...
I didn't give up
If anyone has never version - pls. let me know...
Posted: Wed May 18, 2005 5:41 pm
I've tried it in 98....it doesn't work. I've given up....
Posted: Fri May 27, 2005 11:09 pm
by EJ22_SLO
Dutch friends said this should work... i did't try yet...
Code: Select all
1. Install both of the setup.exe's from the directory cd1 and cd2
2. Copy the contents of both cd's to the folder c:\subaruex (which is the
default folder for the executables from the program)
3. Create a virtual drive with Subst. (go to Start-->Run)
Subst j: c:\subaruex
(you can check if you did this correctly by opening the explorer and see
if there is an J-Drive)
4. Launch Subaru Fast
5. Go to Setup (F3)
6. Set the CDROMDRIVE setting to J
7. Set the other paths to C and point to \SUBARUEX
8. Save Changes via Completion (F12)
9. Now you can use F1 / F2.
To remove the virtual drive:
Go to Start-->Run again.
Subst j: /D
Start Subaru Fast via Start-->Program's-->Subaru Fast-->Subaru Fast.
Posted: Sat May 28, 2005 4:49 pm
Have you tried it? Does it work?
Blue triangle?
Posted: Sat Jul 30, 2005 7:52 pm
by 1993 Legacy
Hi Josh,
Do you, by any chance, know the number of the BLUE one for the left hand i.e. driver's door?
Thanks a million in advance.
Best regards
Dusan
[Anyone know the part # for the little black triangle thingy that covers the screws to attach the mirror?
quote="Legacy777"]found them
94067AA000VG
94067AA010VG[/quote]
Posted: Sun Jul 31, 2005 9:25 pm
I'm assuming you want it for the 92-94 MY's.
They are
RH 94067AA000BK
LH 94067AA010BK
part number
Posted: Sun Jul 31, 2005 10:57 pm
by 1993 Legacy
Hi,
Thanks a lot! Yes, it is for my 1993 Legacy station wagon.
Best regards
Dusan
Posted: Mon Aug 01, 2005 7:32 pm
by LaureltheQueen
I just got part numbers for the 94 GT sideskirts and what I believe to be the rear lip. I'll be doing a bit more research to see if they are actually the case
Posted: Fri Aug 05, 2005 8:45 pm
by EJ22_SLO
Code: Select all
5. Go to Setup (F3)
Subst j: /D
[/quote]
Legacy777 wrote:Have you tried it? Does it work?
It works.. perfect - using instructions above... WinXPpro, SP2...
Posted: Fri Oct 14, 2005 6:29 pm
by Marbles
as a few of you may know, i've started working in the parts department at the Subaru dealership here where i live. So, I have access to pretty much every single part including updated and outdated parts ever made by Subaru.... if you have any parts related questions, send me a PM and i'll get back to you with the part number. I've got the net at work, and i check the board every half hour or so on the weekdays, so it shouldnt be a long time before i can get back to you... hope I can help!
Myles
Posted: Wed Nov 30, 2005 1:11 am
by EJ22_SLO
I've got Subaru Fast 2 - windows edition... works ok with WinXP, SP2....
if anyone has FTP server or knows for a public web server to host files (there are two CDs - one for older (229MB), other for newer models (468MB); i've made two ISO files...) for free - let me know...
For now I've made e-mule (e-donkey) files:
ed2k://|file|SUBARU_FAST2_CD1_OLD_MODELS.ISO|229455872|26D6B3C014ED0E3CC3EC8C1074C0E412|h=QJY5HKE2ZSZZVE2IQAYDK4MPWYETYGI4|/
ed2k://|file|SUBARU_FAST2_CD2_NEW_MODELS.ISO|468959232|46FCFEF76FFEB9E622FE2BAF184DF69E|h=UIAZ5ADXKQY2R5YZ65OHCY6JBLVZ6Q6O|/
screenshot:
http://freeweb.siol.net/odargo/legacy/subaru_fast_2.jpg
Posted: Wed Nov 30, 2005 7:39 am
by LaureltheQueen
email them to me and I'll upload them for a short time
Posted: Wed Nov 30, 2005 11:37 am
by EJ22_SLO
emailng 500 MB
can i ? (using gmail)
Posted: Wed Nov 30, 2005 6:34 pm
by LaureltheQueen
probably, I'm not sure
[edit]can you zip them?[/edit]
Posted: Thu Dec 01, 2005 2:48 am
by mikec
I'm trying to get them off you using eMule, but I'm not sure if there's a problem at my end or not. When are you normally online?
Posted: Sat Dec 03, 2005 6:06 am
by entirelyturbo
Just a little info for you guys...
If any of you wagon owners have broken the little holder clip(s) that keep the cargo cover stretched out... they mount right by the rear window, then you will have a HELL of a time getting the parts guy to understand what you're talking about, and a worse time finding the right diagram.. So the part number for the right side (the left side will be similar) is 65580AA000, and then you have to add the color of your interior to the part number, mine is BK for blue...
I'm posting this, as well as adding the part number to my post on the first page...
Posted: Wed Dec 07, 2005 9:49 pm
by Psychoreo
anyone have the PN for the Pin that connects the gear select lever to the transmission?
