I wondering if it'd be possible to remove an essential component of the ECU and build it into a hard plug-in box that has a connector under the dash
The idea is that even someone who was experienced with hotwiring cars would not be able to start the car, since the computer would be non-functional.
Electronic Killswitch - Hack the ECU?
So you could remove that hard plug-in box when you parked the car?
Sure. There are several fairly accessible important pieces on the motherboard. The ignition output transistors come to mind; or maybe the injector driver transistors. Or the fuel pump driver transistor. Lots of transistors.
If you pop the cover off the ECU's case (four screws; one in each corner), and look at the top of the circuit board (the side with almost all the components) such that all the markings are right-side-up, there's a 10-pin single-inline-pin chip on the upper right of the case. If you remove the clamp holding it to the side of the case (one more screw), you should see that it's a Hitachi 4AC14. I believe this is the chip that drives the four injectors.
When you mount it remotely, be sure it's mounted to a decent heat sink. Use heat sink compound on its mounting surface too.
