What front strut bar to run with AWIC
Brat4by4
Stratified
Post by Brat4by4 »
shemoves wrote:Are the dimensions the same? Assuming an IC or something else was not in the way, will any GC strut bar fit, or are you saying that just the strut-top mounts are the same?
The orientation of the strut top bolts and the spacing between them are the same. The slope of the hood, etc. are different. So a lot of GC bars are raised above the mounts and that will hit the hood on a BC.
So you have to check and see for each bar unless you know someone specificially has that bar on their car with no modification.
farfrumwork
Post by farfrumwork »
Yes, most GC bars will fit but *may* hit the hood.
As I've posted - the Cusco bar fits with limited modification (certainly less than producing an entire bar). Look for my pics in the picture forum and you can see the Cusco mounted.
I like the bar - it works well and looks tits too! :D
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
I may have to try the cusco bar next.
shemoves
Post by shemoves »
What 'modification' did you have to do to get it to fit?
farfrumwork wrote:Yes, most GC bars will fit but *may* hit the hood.
Can you show me in this pic, or take another pic of what exactly you ground down/modified on the mounting plates to get them to fit?
http://i98.photobucket.com/albums/l252/ ... 87_IMG.jpg
farfrumwork
To use the Cusco STB, you must grind down the front upright on each mount plate. probably 3/16" off the highest point, blended into the shape of the suport member.
In the pic Josh posted above, you can barely see the ground-down area on the passenger side plate.
I will try to get some more detailed pictures.
-Chad
Thanks Chad.
Well I found one that works. It's the red tubular steel SPT bar. Part # is E4010FA000.
The bar touches the hose for the coolant overflow...but that shouldn't be a big deal.
Here's pics
http://www.main.experiencetherave.com/s ... /sptbrace/
Brat4by4
Stratified
Post by Brat4by4 »
$134 shipped from www.subaruparts.com - not bad.
Good find, Josh! Now I just have to see what I can sell that would total over $130...
This was the last big piece to getting my suspension/stiffness goals achieved.
Yeah....it's a very reasonably priced bar. I got this one used for an amazingly screaming deal :)
dscoobydoo
Post by dscoobydoo »
That seems the same thickness as the carbon fiber GC8 bar.
You might be able to find one of those used for under $130.
I have one, and it actually just touches the firewall.
So that might give you more room.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
I don't think the carbon fiber one would fit....I think you'd get interference with the brake MC and possibly the cruise actuator.
Plus, you can get the steel bar I have from Jamie for $114
jefferson
couple questions
Post by jefferson »
Love the pictures. Josh your engine bays is so clean and detailed. It rocks. Now for the questions.
What pulleys are on your car Josh?
And where can I get info on the g-performance awic. I have searched several times and found nothing.
Thanks,
Jeff
jefferson
Post by jefferson »
Sorry about the typo
g-force performance awic
Jeff
Thanks for the comments Jeff.
The pullies are N1 lw pullies.
http://subaruplanet.com/pulleys.htm#pulley
The AWIC is an OEM subaru AWIC core, with custom pump & radiators.
I've got a thread with more info in the intercooler forum if you would like more details.
jefferson
Post by jefferson »
Yeh I knew yours was a factory one. The guys down under ought to know what fits as those intercoolers came on their cars from the factory.
The picture you posted of the car with the Cusco bar had a G-force performance awic on it. Do you know anything about them or where to get one? It looks like it leaves some room in back, but is it any good. I haven't been able to find anything in any search I have done. Surely someone here knows something about it.
Jeff
The other one is Chad's (farfrumwork), so I'd shoot him a PM about that stuff.
Re: What front strut bar to run with AWIC
Resurrecting an old thread, I PM'd Legacy777 about his experience with the red SPT strut bar. After checking the prices, I decided to order one from my local dealer. They must be on clearance or something because I got it for just under $80!
Tested it on my friend Florin's car with an 06/07 WRX TMIC and it fit perfectly. As Legacy777 mentioned, it also clears the AWIC core, where even the carbon fiber Impreza one doesn't.
Part #:
E4010FA000
For pics, see Legacy777's posting above.
I had no clearance issues with a STi carbon bar and my AWIC.
Interesting, scratch what I said then.
1stsubaruparts.com has it for $69.60 plus $12.95 shipping. E4010FA000
^^+ Tax in Washington for 1stSubaruParts and SubaruGenuineParts. That's why I bought it from a dealer since it came out slightly less than from online. It was shipped (not)overnight from Japan, took a week, lol. My receipt shows they charged me $78.
