so i fried my last ecu, and just put the new one in today. and i finally got to drive my car after the 5mt swap for the first time. and it drove awesome.
but i am throwing a code 45 which is the abnormal map sensor voltage. I have a hks fcd which has always worked great and i have not touched the wiring on it since i installed it( which was over a year ago and has always worked great).
I measured the voltage going into the fcd and it read 5 volts at idle. which i am pretty sure its normal. and i had 5 volts leaving the fcd going to the ecu. Then i adjusted my fcd and measure the voltage in and out, and it seems to be doing its job.
i checked all vacuum lines going to the MAP and they are all connected and seem to be correct. i cant understand what the hell is going on. anyone have any ideas
Code 45, MAP. any ideas?
thehookeup
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
thehookeup
Manarius
AFAIK, the EJ22T was not equipped with a MAP, but a MAF.
Seems to me that the pressure sensor or exchange solenoid valve is inoperative.
thehookeup
well im retarded as we all know. haha. i had the pressure exchange routed after the the vacuum delay valve for the charcoal canister. lights are off and the car is hauln ass
Andrew
Andrew
