what is this connection beneath the drivers seat?
slowjoe
Post by slowjoe »
1
it is the connection on the lower right hand side of the picture.
2
same thing, just backed out to show you where it was in reference to other things.
94 AT FWD N/A wagon-gutted daily driver.
Post by SubaruNation »
looks like it is connected to the ABS, and from there to the ignition.
when you turn your car on, you can hear the abs lines start up.
pretty sure that's what that is.
maybe..... :?
If you follow the wire on the seat, it goes to the seat belt buckle. I think it's supposed to be tied into the seat chime, but on my car, I don't believe it does anything......
slowjoe
Post by slowjoe »
subarunation-i dont believe i have abs. but i do hear something when starting up. before i crank the engine, when the key is just in the on position, the position that lets you get the check engine codes, i hear a noise. it sounds more like a pump.
josh-i wasnt talking about that. i am talking about the connections next to the door. they are currently connected. the seat belt wire is disconnected because i dont have the stock seat belts or the stock seat anymore.
ahem,
these are abs lines. they have to be
the other thing you might be hearing is either the brake booster or maybe the PS pump.
SubaruNation wrote:ahem,
Nope, the brake lines run on the passenger side of the car.
Those lines are the fuel supply, fuel return, and evaporative emissions lines.
well they sure look like my ABS lines. good to know however :D
legacy4ever
Re: what is this connection beneath the drivers seat?
Post by legacy4ever »
slowjoe wrote:it is the connection on the lower right hand side of the picture.
power windows harness.
Ben
93MY EUDM Legacy EJ22
asc_up
Post by asc_up »
slowjoe wrote:subarunation-i dont believe i have abs. but i do hear something when starting up. before i crank the engine, when the key is just in the on position, the position that lets you get the check engine codes, i hear a noise. it sounds more like a pump.
What you're hearing is your fuel pump pressurizing the system.
quicklook
Post by quicklook »
that is correct. when my windows stopped working i had to mess with them. the circuit breaker is there if i remember right.
