braille battery
braille battery
thinking about getting a braille batery.
http://braillebattery.com/
if i went with the lightest one. what would be the problem with running this one the small has 527 pulse cranking and 10 amp/hr reserve
my battery now has 8XX cold craning and not sure about the reserve however i now i use it when i work on the car and it will last for a good bit. plus 3 hours before i turn the car off just in case.
the 9 pound has 813 pulse craning and 12 amp/hr reserve
GodSquadMandrake
Their not good for daily driving if that's what you have in mind. They won't work well in the cold and you can't just play your radio for hours and expect it not to be drained. Their kind of like camera batteries from what I've heard. They have high energy but only for short periods.
I personally just went with a smaller wet cell battery from a Honda Civic. It was like half the weight but still provided good performance all through winter provided I didn't do anything stupid like leave me lights on and I didn't have a big stereo either so that wouldn't affect it. The grounding kit and gold terminals I installed helped too with the cranking powa.
-Doug Wilson
I had a braille for a couple of years - it worked ok but like GSM said it was for fair weather use only...I'd probably have a summer and winter battery on a daily driver.
hmm interesting. so what if i went with like the 9 lbs or the 12 lbs would that be even better
but they would make a difference to a AWD car?555BCTurbo wrote:The weight savings/general hassle would make zero difference to your FWD NA car...
NoSILINC3R wrote:but they would make a difference to a AWD car?555BCTurbo wrote:The weight savings/general hassle would make zero difference to your FWD NA car...
Put the battery in the trunk. That's my next project re: battery...
thanks that was my point on his point. i think it would be cool to have the battery and a little less weight wouldnt helpLegacy777 wrote:NoSILINC3R wrote:but they would make a difference to a AWD car?555BCTurbo wrote:The weight savings/general hassle would make zero difference to your FWD NA car...
SLODRIVE
IDK, I kinda like the looks of those batteries. They're about the same price as an Optima but way, way smaller and lighter. Saving 25 lbs. or so isn't a bad thing at all IMO.
http://www.slodriveracing.com
-And more!
-And more!
I have the small Odyssey pc680 in my car and have had no issues with it. I don't have a big stereo in it either. I don't know how the Braille compares to the Odyssey though. I didn't write anything down, but I did weigh the old battery and if I remember right I lost about 15 pounds.
Jeff
Jeff
