Engine Knocking
Engine Knocking
I have a 93 touring wagon with a jdm ej20g. Not too long ago i noticed my car was sounding different and maybe only running on 3 cylinders? It starts to shake when the rpms start to go back down after starting. I drove it around a bit and i noticed when it accelerates it knocks. This is quite scary and im just wondering what could be wrong with it.
alexandermf
Re: Engine Knocking
How loud is the knock? It could be anything from hydraulic lifters ticking to rod knock...
Re: Engine Knocking
its not too loud but i dont really have anything to compare it to..
robertpaige
Re: Engine Knocking
Post a video.
Re: Engine Knocking
Ok heres the deal. One day i started my car up and it ran perfectly and it hasnt done anything since. What could this be? Could the timing have been off?
robertpaige
Re: Engine Knocking
The knock your talking about may have been lifters? They can tick pretty loud and be mistaken as a slight knock and can come and go. A rod knock will never go away or fix itself. Does the car still shake?
Re: Engine Knocking
Accidently put some 87/89 octane gas in it? My Touring Wagon got filled with 89 once and it knocked/shook quite a bit. Problem was gone as soon as it got filled with 93 again.
Re: Engine Knocking
No only 92 octane..
Re: Engine Knocking
the problem does sound alot like how you decribed with the shaking and knocking and then after revving it goes sub-500 rpm......
Re: Engine Knocking
could this be caused by a bad ecu because im trying to figure out whether i should get a robtune ecu or not because 380 is a bit much if its not going to fix anything.
robertpaige
Re: Engine Knocking
I doubt the ECU just went bad. Get the car running good before you do any modifications or tunes.
Is the issue still happening? or did you say that it went away..
Mister Anderson
Re: Engine Knocking
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
