what shot should i use
i just bought a wet nitrous kit and was looking for what shot i should use for maxium gain without blowing the motor to kingdom come on the first run. any info or advice would be nice
-jason
If you are planning on using a wet kit for long periods of time, I strongly suggest getting an EGT sensor. It'll let you know if anything has gone amok or if something is getting too hot and about to melt away. EGT should tell you if you're getting too hot and that you should back off a little.
Other than that, you should get up around a 50 shot.
Run like a 25 shot under WOT and only while the turbo is spooling. Couldn't be TO hard to program (if manifold pressure is below a certain number, and TPS is a certain volt, then spray, otherwise, don't).
That'd be a nice anti-lag setup, but I bet it'd be hell on the rod-bearings.
I just picked up an extra nitrous system today that shoots a 300 shot. Should I try it?
Joking!!!
I have a little ebaying to do to get rid of the extra parts now.
Joking!!!
