cam profiles for n/a ej22?
greg donovan
Post by greg donovan »
where could i find the profiles for my '90 ej22 camshafts?
if i were to spend more money on my ej25 block/ej22 head hybrid project i would like to spend it on cams.
what type of profile would i want?
longer duration or greater distance opened? or both.
im tempted to scrap the whole damn thing and focus on a front LSD and a final drive and gear ratios more suited to acceleration and getting what little power i have to the ground better.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
the fsm does have cam info. Whether it's all correct....that I can't tell you.
greg donovan
the actual subaru ones or the haynes/chilton's FSM?
96 Impreza L sedan
00 Impreza RS sedan
I posted some info from the 92 FSM in this thread:
http://bbs.legacycentral.org/viewtopic.php?t=14770
factory manuals. It should be in the engine section, which is d/l via my server....there's a sticky in the things you should know forum.
greg donovan
is there much of a difference between the 90 FSM and the 92 FSM regarding engine specs?
96 Impreza L sedan
00 Impreza RS sedan
depends on what you're looking at. I have the entire set for the 90 legacy at home. If you find some data in the 92 set, let me know specifics and I can check it against the 90 fsm's.
greg donovan
ok thanks. that is alot of scanning that guy did no wonder some of the pages are a bit crooked. i keep finding my head tilted to the left while reading that stuff. thanks for sharing. i space out the stuff you need to know thread for some reason.
96 Impreza L sedan
00 Impreza RS sedan
