Detailed AWD & 5MT Swap Write-up completed
Hocrest
Post by Hocrest »
The richness was due to not plugging the MAF harness back in when I was done with everything else...
I ended up running a new wire to pin 81 on the ECU and grounding it. Seems to have fixed the CEL.
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
Good to hear
253.Asmo
Post by 253.Asmo »
I think I've read the swap wiring write-up about a hundred times (that's normally how long it takes my non-linear brain to figure shit out like this)
My question is that in this picture
It looks like pin 4 from the B15(mt) is wired into pin 9 on the AT side, and pin 2 goes to pin 10.
According to to the write up, it should be the other way around no?
Please help me clear this up. Thanks!
Matt[/img]
You have to remember in that picture, that is not the B15 side of the AT connector, that is actually connector E18, which has the pins inversed when compared to the AT B15 connector.
This scan may help.
http://main.experiencetherave.com/subar ... ectors.pdf
Not sure if that answered your question. If not, please let me know.
253.Asmo
Post by 253.Asmo »
I figured that out as far as the AT side went.
But... the only way I end up with the same colors/orientation as the harness in the picture, is if pin 1 on the smaller mt plug (B15) is (looking head on with lock facing down) top right. black red.
I thought as chassis side this should have pin 1 as the green/yellow in top left (with lock facing Up head on)
thanks!
skid542
Post by skid542 »
Does it really matter which pin goes to which pin as long as the neutral wires, both sides, are connected and the reverse wire, again both sides are connected?
The switches on the tranny are just simple N/O or N/C switches correct? No diodes?
Lee
That plug in the picture is the actual automatic transmission plug. I cut it off the transmission and used it as a plug and play harness. The FSM doesn't give you those wire colors for the transmission side, only the chassis side.
Sublimejoe
Re: Detailed AWD & 5MT Swap Write-up completed
Post by Sublimejoe »
I have been thinking of undertaking this on my car, just a few questions on what I may or may not need.
My car is already AWD, but aside from that it is an Automatic 93 Legacy. It is also RHD, so I don't know if that would change anything. Any info you could provide would be greatly appreciated!!
Edoit: Also, is there a reason you went with that specific trans? I have a five speed tranny from a 2006 Forrester sitting in my garage so if that would work things would be much easier (and cheaper.)
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
ride_child
Post by ride_child »
i believe josh went with the six speed becuse theyre a stronger transmission capable of holding more power without grenading.
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
Sublimejoe
ride_child wrote:i believe josh went with the six speed becuse theyre a stronger transmission capable of holding more power without grenading.
Ah, ok. I have an n/a EJ22 so I'm not overly worried about power haha
Parts Needed:
Manual Cluster
Sublimejoe wrote:I have been thinking of undertaking this on my car, just a few questions on what I may or may not need.
The main difference on the RHD car is going to be the pedal box assembly. In looking through my list of parts that's the only thing that stands out. If you use a hydraulic clutch setup you will also need the RHD clutch master cylinder, hoses, and maybe clutch slave cylinder.
Originally, I used the turbo legacy transmission because I knew I wanted to go turbo at one point. The 06 Forester transmission would work as long as you install the matching rear diff. I do not know what the Forester's final drive ratio is, you'll need to match that. Keep in mind that swapping the forester rear diff in would likely require different rear axles, so I'd recommend finding out what the final drive ratio is and find an older style rear diff to match.
Sublimejoe
Sorry for the super delayed response.
I picked up a transmission from a 1996 Impreza, and just last week my RHD Legacy pedal box arrived. I am looking at your parts list now, trying to figure out what I still need to grab. I assume I will need the transmission ecu from a 96 Impreza... right? Anything else big you can think of?
Parts Needed:
Manual Cluster
Sublimejoe
Another quick question, do I need to buy the clutch master and slave for the body (93 Legacy) or the tranny (96 Impreza)? Thanks!
Parts Needed:
Manual Cluster
Clutch master and slave needs to match transmission & especially pedal set type. Didn't you say you bought a RHD cable pedal set? Then you need the appropriate cable and transmission fork. Master and slave cylinders are not used in this setup.
wtdash
Post by wtdash »
Sublimejoe wrote: I assume I will need the transmission ecu from a 96 Impreza... right? Anything else big you can think of?
Hi,
Thread's getting a little stale (again), but there is NO TCU (trans computer / 'ecu') for manual cars... @ least prior to '99. And you CAN use the same ECU (engine computer) on your '96 for both AT and manual transmissions.....I state this w/some hesitation as you're not in the US (RHD) and not sure if that's 100% true overseas.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Sublimejoe
I actually am in the US, Virginia to be exact :)
According to my research the manual trans from the 96 Impreza has the same final drive as my 93 Legacy 4eat, which is 3.9 Is that correct?
I would still need to use an ECU that matches the motor I am putting in correct (EJ20g) since it is turbo and my car is originally N/A
Parts Needed:
Manual Cluster
Sorry, I've been MIA for a while.
As others have noted, you don't need to run the TCU when going to MT. The ECU needs to match the engine you plan to run. Most of the ECU's of this era can run either MT or AT with the appropriate wiring setup.
If the 96 Impreza is like My 97 Impreza then yes it should have 3.9 final drive ratio. You can look at the diff stamp to confirm. The 93 AT rear diff is 3.9.
http://www.main.experiencetherave.com/s ... f_info.pdf
OneToolAtATime
Post by OneToolAtATime »
I did a 5 speed swap on my 92 legacy wagon (ej22e) awhile ago. I snipped the at/mt identifier wire at the ecu and I am still suffering from high idle. It isn't all the time, just whenever it wants to. I do not have a vacuum leak (that I've found) and the tps should be fine considering it was set in the same position. I removed the tcu and cruise as well. I can drive it fine as is, but I am going turbo next, so I would like to get this sorted out first. Should I ground the wire I snipped or try reconnecting it? I was a little confused in the write-up when the ecu was switched. Thanks.
OneToolAtATime wrote:I did a 5 speed swap on my 92 legacy wagon (ej22e) awhile ago. I snipped the at/mt identifier wire at the ecu and I am still suffering from high idle. It isn't all the time, just whenever it wants to. I do not have a vacuum leak (that I've found) and the tps should be fine considering it was set in the same position. I removed the tcu and cruise as well. I can drive it fine as is, but I am going turbo next, so I would like to get this sorted out first. Should I ground the wire I snipped or try reconnecting it? I was a little confused in the write-up when the ecu was switched. Thanks.
If you have the 92 ECU that I had then the MT/AT identifier pin should be grounded. However, if that pin was already grounded then it may be different. Do you have a multi-meter you can check whether that wire has continuity to ground? Are you sure that was the correct pin?
I would think the high idle issue should be consistent if it was ECU related.
WRXish
Re:
Post by WRXish »
Legacy777 wrote:Yeah....it is the best resource we have.
I like my 90 FSM's because they were used by a mechanic. They are "dirty" they have been updated with new info. There's sections where he taped in the new info over the old stuff. So I like to think the 90 fsm's info is more correct then my 92-94 set because those are brand spanking new.
Was just wondering if there is still a resource for a set of FSM for the 90-91 Legos?
If you are wanting paper copies my best suggestion would be to check out ebay or keep you eye on the parts shed. I've seen a couple sold over the years.
Ebay has a couple options now Check me out
