Page 5 of 24
Re: EJ20G "RobTune" Info
Posted: Thu May 13, 2010 5:52 pm
by dscoobydoo
brand wrote:So if I'm following this correctly, you're looking into modifying the EJ22T ECU so you can put your tune on it, and if that runs into snags then the options is to wire the car to run an EJ20G ECU?
YEs that is correct.
Posted: Fri May 14, 2010 2:16 am
by rob
Well in a perfect world I would have you guys switch to the EJ20G solution and be done with it. That is what initially led me here was the people begggggging me to let them try it out :P As more data rolls in, I will have a better handle on what to recommend if you want to follow this path. In addition to that, I am looking into what it would take to step into chip tunes for the EJ22T ECU. So best case, you would have both options, worst case it's the G route. I wouldn't necessarily take what I have now and adapt it over, I don't think that would necessarily give the best results, but that's to be seen.
Posted: Mon May 17, 2010 5:41 pm
by Florin1
Going in for a baseline dyno today @ Drift Office.
Posted: Tue May 18, 2010 4:25 am
by Josh222
results?
Posted: Tue May 18, 2010 5:53 am
by Florin1
Posted: Wed May 19, 2010 1:08 am
by Tommio RS
Very nice Florin1!!!
Your car looks mint aswell!
I envy you...
Posted: Wed May 19, 2010 4:00 am
by Florin1
Thanks. :-) I try to keep her clean.
Posted: Mon May 31, 2010 7:28 am
by rob
Thanks to Drew for loaning his machine for testing. Is there a how-to for extracting the ECU? That thing is really wedged in there!
-Rob
Posted: Mon May 31, 2010 2:45 pm
by cj91legss
lol, yeah it's kind of a hassle. but if you remove the 2 nuts on the fuse box and pull the fuse box off their studs and move it over, you should be able to remove the 2 nuts off the ecu and just pull it out.
Posted: Mon May 31, 2010 9:40 pm
by Florin1
yey for progress... :-)
Posted: Wed Jun 09, 2010 6:56 am
by MikeyMeyagi
Got my +4 timing chip from Rob, and have about a half a tank thru that, and my EWG setup i fabbed up. Now that the ecu has learned a little, the car is F***ing fast. Im hitting 18psi tapering to 15psi, with no signs of knock, and good AFR's. Next will be to try the +7 timing map i got from Rob, and hopefully soon ill get motivated to install the 20G cams i have.... i think the cams will make a really noticable difference, at least i hope they do!!!
Posted: Thu Jun 10, 2010 1:35 am
by Florin1
Hey Mike, so you're putting ej20g cams on n/a heads?
Posted: Thu Jun 10, 2010 2:54 am
by MikeyMeyagi
Florin1 wrote:Hey Mike, so you're putting ej20g cams on n/a heads?
Yes
Posted: Fri Jun 11, 2010 7:37 pm
by legacylok
does anyone know where to get a ej20g ecu?
i have an ej20g engine i just cant find an ecu
rob if you have any extras i would love to buy a tuned one off you
Posted: Mon Jun 14, 2010 2:07 am
by rob
legacylok wrote:does anyone know where to get a ej20g ecu?
Actually I don't anymore. I suggest checking with JHOT or East Cost Swappers since they import a lot of JDM parts. They are all over ebay UK and scoobynet as well (also in the UK).
MikeyMeyagi wrote:Got my +4 timing chip from Rob, and have about a half a tank thru that, and my EWG setup i fabbed up. Now that the ecu has learned a little, the car is F***ing fast. Im hitting 18psi tapering to 15psi, with no signs of knock, and good AFR's. Next will be to try the +7 timing map i got from Rob, and hopefully soon ill get motivated to install the 20G cams i have.... i think the cams will make a really noticable difference, at least i hope they do!!!
Yeah great results back from Mike. I would like to see how it runs with the 3rd map and see some dyno results!
cj91legss wrote:lol, yeah it's kind of a hassle. but if you remove the 2 nuts on the fuse box and pull the fuse box off their studs and move it over, you should be able to remove the 2 nuts off the ecu and just pull it out.
Shortly after I posted, I got the ECU out. Man what a PITA. I am spoiled with mine being right under the passenger foot well on my impreza. I was able to extract the stock ECU code and build my own prototype board for testing an add on eprom. Apparently in my playing around I did something bad and think I killed Drew's ECU. :( So now I am looking to find him a replacement. If anybody had one they would part with, send me a PM :) Still it is a small bit of progress. Next on the list for the donor is to fit my 20G ECU with my super secret 4to2 ignition converter.
-Rob
Posted: Mon Jun 14, 2010 3:41 am
by Florin1
hey Rob, I'm making progress on my engine too, i think i'm gonna be getting the DOHC heads on late this week, or next. Now about this super secret 4 to 2 converter... :twisted:
Posted: Mon Jun 28, 2010 4:03 pm
by cj91legss
Any updates?
Posted: Mon Jun 28, 2010 10:28 pm
by fatgc8
I have a ej20g swap with a ej22t harness and ecu. The car is auto right now but will be converted over soon. My question is if i were to purchase a ej20g ecu and run the auto would this effect anything if the 20g ecu was Manuel or would i have to get a auto 20g ecu?
Posted: Tue Jun 29, 2010 12:26 am
by rob
cj91legss wrote:Any updates?
Not much in the past couple weeks. First I was waiting for a replacement ej22t ECU which I picked up last week. In addition I had a national rallycross event this past weekend that I was preparing for (and yes, I did pull 1st place in modified awd :D ).
Now that that's all settled, I'm ready to get back to it. My next steps are to try my eprom add-in board prototype again (this time without burning out the ECU!). After that I'll do the rewire for the EJ20G ECU and give it a go. Drew's car is perfectly setup to try my tune on, so maybe I can talk him into hitting the dyno...
Also I have a few more spare EJ20G ECUs on the way for those looking for one.
fatgc8 wrote:I have a ej20g swap with a ej22t harness and ecu. The car is auto right now but will be converted over soon. My question is if i were to purchase a ej20g ecu and run the auto would this effect anything if the 20g ecu was Manuel or would i have to get a auto 20g ecu?
In theory, the ECU shouldn't care.
-Rob
Posted: Tue Jun 29, 2010 2:33 am
by dscoobydoo
Yup- figure when we get the final modified tune on there, we will hit the dyno at PIA and see what she puts down.
Posted: Tue Jun 29, 2010 4:55 am
by cj91legss
so if you have an ecu already for sale, how much is it?
Posted: Tue Jun 29, 2010 5:58 am
by Florin1
"Logistics/Costs
I charge $280 for fitting the chip to an ECU board, the chip, the tune and return shipping. Logistically, I either have the ECU sent to me directly, modified then shipped back, or I modify one of my spare ECUs, ship it out and have the recipient send back theirs. The second option is usually preferred as it prevents any downtime. The only hitch is that I require a refundable $200 deposit to help motivate the speedy return of the exchanged ECU." ;-)
Posted: Tue Jun 29, 2010 2:37 pm
by cj91legss
Florin1 wrote:"Logistics/Costs
yeah, that's just to chip our ecu but it didn't quote a price for buying an ecu was from him. I pm'd him about that price and got an answer then.
Posted: Fri Jul 02, 2010 7:37 am
by crashnburn
Nice progress rob. I look forward to when you release this. What is the differences between your chip and the revtronix chip?
Posted: Sat Jul 17, 2010 2:52 am
by kbeefy
cool, any updates? Was pretty bummed when revtronix dissapeared, I've got all the supporting bits and was hoping to up injectors this summer.
