Oh nice - I was planning on attending but didnt get snow tires or chains yet.
Sold my turbo Grille to CFK
I spent about 12+ hours working on the car and prepping everything to get the 6spd in. I fixed & repinned the trans wiring harness, installed shifter bushings, 6spd lower flywheel cover, and the 6spd flywheel, pp, & clutch.
Pics
http://www.main.experiencetherave.com/s ... spdswap/11
I just have to grab a friend or two and another jack to muscle that monster in the car. I'm not looking forward to it.
Yeah, those 6speeds look pretty beefy. I wonder what they weigh...
Grabbed a heater core from a junkyard car. Picked a car that had 300k miles, cause hopefully that means it was replaced. Core itself does look new, but I suppose they don't get very dirty where they are located.
30 mins to pull dash, another 30 minutes to pull core, lol. Dash I pulled myself, Vica143 helped with the heater core.
I think I blew my turbo today...
cj91legss wrote:I think I blew my turbo today...
Oh Noes! what makes you think that? Check your spark plug wires, I had a couple that backed out that made me think it was the turbo.
It's making a funny noise as soon as it starts to spool and it sounds like something is boiling inside the downpipe :(
Yeah it blew, wont even build boost. video of sound coming soon
Kimo's got that td05... ;)
yeah but it's not bolt of for my application. Unless you know where i can get a different compressor housing for it to fit my intake setup?
georryan
Post by georryan »
I chopped up some blown RS struts and put koni inserts into them. When I get the rear bump stops I will put them together with my p1 springs and see how they compare to the AGXs.
Sent from my Galaxy Nexus using Tapatalk 2
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
cj91legss wrote:yeah but it's not bolt of for my application. Unless you know where i can get a different compressor housing for it to fit my intake setup?
Prob not practical for you. But you can buy td05 housings on ebay, including a twinscroll type. If I ever get around to getting a twinscroll manifold that's what I'll do and reuse my td05.
Might have to buy a Chinese turbo :-(
cj91legss wrote:Yeah, those 6speeds look pretty beefy. I wonder what they weigh...
Trans shipping weight was 215 lbs. So it's right around 200 lbs....definitely a beast!
Someperson
Post by Someperson »
How much did the 5 speed weigh?
93 Winestone TW project
Not sure. I'll have to throw it on the packaging scale I have and see how much it weighs.
I'll probably try and do that with both the 6spd & 5spd so I've got a direct comparison.
Someperson
Rented a uhaul and spent 10 hours transporting my auto TW to my driveway on sat. Wish i had the space to salvage it instead... But sadly i already own 3 cars not including my gfs... So 5 cars total... Need to stop this >.<
originalcyn
Post by originalcyn »
Finished installing my accessory mount.
The top is a ball jointed universal mount. Once positioned, the joint can be tightened down so that the base can't move.
The bottom is a boot made of fairly sturdy metal. It was straight, but to mount it using the chair rail bolts as suggested, the boot had to be bent quite a bit.
The middle is an aluminum bar about the thickness of a sharpie that is 18 inches long. The cover is simply wire loom that has been sealed shut.
Because of the gauge of the bar, there's not a lot of movement once the position is set, unless you put some real weight behind it. So it's not going to collapse or anything like that, which is really nice.
Kijan
1993 Legacy LS | PBM 227
sqc151
Post by sqc151 »
should put it on the passenger side so its not in your way and also reach to your radio and 1/2 din pocket.
originalcyn
Thought about it, but it basically is the interface for my music, so i like to have my hand on the wheel when i switch tracks, which i can do in it's current position.
Kijan
SiCkSTi04
Post by SiCkSTi04 »
originalcyn wrote:Yeah no problem. I stole the idea from SiCkSTi04, but I wasn't sure if that cargo tray would fit in the sedan or not. So at 20 bucks...why not.
Your Welcome :)
The forester cargo tray fits our sedan trunk very well. The newer legacy tray also fits our wagons too.
http://bbs.legacycentral.org/viewtopic. ... 6&start=50
originalcyn
Have you tried the legacy tray in a sedan? I'm curious about that. I love the forester one, but i'm just too vain about it saying forester instead of subaru or legacy.
Kijan
Dominator
Post by Dominator »
Fixed a small fuel smell / leak. Just loose hose clamps at the fuel filter. I've got a wicked headache now though.
