Danny-G
Post by Danny-G »
Here's the result of my painting.
Danny
92ColoradoTurbo
Post by 92ColoradoTurbo »
PREPARE FOR PHOTOS!
Discovered that my low fuel light works! I'm guessing it comes on when you have two gallons left because I drove to the gas station with it on for a bit and filled up 14.1gal and we have a 15.8gal tank I believe. Also took her on a road trip to Tarryall Reservoir, Colorado.
Sent from my XT1080 using Tapatalk
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
Scuba75
Post by Scuba75 »
Replaced all four struts and mounts on my 93 wagon with KYB G2's, plus replaced a broken headlight and turn signal.
208ss
Post by 208ss »
Ordered whiteline front 22mm swaybar and heavy-duty endlinks
1991 subaru legacy sport sedan
CAV3MAN227
Post by CAV3MAN227 »
-I've only seen my gas light come on once in over 5 years I've owned the car and that was only because I was low on fuel and on an incline on a driveway. Never seen it since.
-Joe
James614
Post by James614 »
Killed it, somehow. Died while idling, wouldn't start backup. Has two codes for MAP and IAC but I think those are stored. I really hope its the fuel pump.
208ss
Post by 208ss »
Installed my whiteline swaybar and endlinks
James614
Post by James614 »
Just had an Exedy LW flywheel and Stage 1 Clutch delivered. Now I can hopefully get to 15psi without slipping :)
James614
Post by James614 »
Installed my flywheel and clutch. I really wish I had just followed the FSM instead of winging it, then I may have realized you have to remove the clutch fork pivot shaft and take the fork out of the release bearing before the trans will come out
Edit: I really want to switch to the '06+ push style turbo trans now.
dankberries
Post by dankberries »
Installed a new torque converter seal today and put the engine in. I was in such a rush to pull the engine I had completely forgotten about removing the torque converter and damaged the seal when pulling the engine, also made for one hell of a mess with stinky atf every where. BTW I absolutely hate auto trannys! I'm so pissed I'm putting this back together w/ the auto. 5speed soon!
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
killajamal
Post by killajamal »
@Robertpaige your sedan looks f***ing rad my friend! Love it! So clean. What suspension you running?
208ss
Post by 208ss »
Got one of my wrx seats installed
jamal
Vendor
Vendor
Post by jamal »
James614 wrote:Installed my flywheel and clutch. I really wish I had just followed the FSM instead of winging it, then I may have realized you have to remove the clutch fork pivot shaft and take the fork out of the release bearing before the trans will come out
No you don't. I had my clutch fork crack at the pivot last year which was not fun to replace. It's pretty common on the newer WRX.
Also you can detach the throwout bearing from the pressure plate with a long screwdriver instead of pulling the pin.
turbo970
Post by turbo970 »
got rid of the fart can muffler and got the obx muffler put on
Danny-G
Post by Danny-G »
New wipers all around, wagon has been treating me pretty well overall.
Danny
208ss
Post by 208ss »
found out that my transmission is going out the rear bearing is whineing like a mofo
killajamal
Turbo front end conversion. Plastidipped my hood, painted the front bumper, license plate hard-delete, custom front grill(inspired by the newer forester grill look) and blacked my lights and corners.
208ss
Post by 208ss »
Bought a ppg straight cut gear transmission because my stock went out.
CAV3MAN227
-Put some new tires on the car. Re-arranged some electronics in the cabin.
-Joe
94EJ22
Post by 94EJ22 »
Got new rims put on, changed the oil and ran it through a car wash.
1994 Subaru Legacy L Winestone Pearl
James614
Post by James614 »
jamal wrote: Also you can detach the throwout bearing from the pressure plate with a long screwdriver instead of pulling the pin.
I tried this, there was no way a screw driver would fit in there at the angle we needed. But after the first try its cake undoing the fork in the future.
208ss wrote:Bought a ppg straight cut gear transmission because my stock went out.
Did you buy the 4.44 tranny that had been for sale forever on nasioc? Considering the parts and labor put into it, that was a steal!
CAV3MAN227
-Painted a manifold, ready to go on tomorrow.
-Joe
dillonr92
Post by dillonr92 »
Over the last month ive done all this.
I installed coil overs.
New catless TBE straight pipe.
Did a compression test.
Throttle body coolant bypass.
Installed a different maf.
Cleaned that maf.
Cleaned the iacv.
Installed td04/tmic..
Next up is water pump and timing belt and a few seals.
Then I have a five speed swap that needs to be done.
And the last thing I have on my to do list is pick up these headlight housings my buddy has. And clear the lenses, paint the housing black and then retro fit them.
Sent from my SCH-I545 using Tapatalk
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
Please remember to hit return after each picture so the pictures scroll veritically vs. horizontally out to the side.
I fixed these.
