Page 2 of 2
Posted: Sat Feb 28, 2004 3:45 pm
by mTk
stant093 wrote:
evolutionmovement wrote:You've got to watch those intake manifolds - you don't wantt hem blowing up and taking out your diamond plate floor boards.
huh??
TFATF baby!
MK
Posted: Sun Mar 07, 2004 5:19 am
by stant093
ok, did the work today, took from 10am to 4:30pm and had no help unfortunatly....everything went fine and car is running beautifully again, thank freaking god!
i got some good pics if someone could possibally host them... :D :D
Posted: Sun Mar 07, 2004 5:22 am
Niiiice.
I'll PM you my email address so you can send the pics to me.
Posted: Sun Mar 07, 2004 5:51 am
by stant093
yeah, thats the first time i had to tear apart an engine and HAVE to have it work again :) usually its burnt up engines and crap, learning how to take crap apart and NOT break stuff....thing started second crank of the engine then backed down to its normal 700 rpm and not the 3k rpm it was shooting up to when cold starting.....finally its running like it used to, perfect and silently....while i was at it i removed the AC compressor as i never used it seeing it wasnt charged one bit, i figure if i dont use it why have it...also replaced the alternator belt and fresh power steering fluid as it was dirt cheap....
edit for the pics (curtosy of Vikash) Thanks buddy!
starting the removal process
the leakey gasket
all removed
all set and ready to go....
it actually went easily....
Posted: Sun Mar 07, 2004 6:22 am
by THAWA
e-mail the pics and i'll put em up.
good that everything is working now
Dunno if you knew this but the defrost selction uses the ac compressor for whatever reason, something to do with the air or something. anyway, I dont know how tat's goingto affect you now. but yeah.
Posted: Sun Mar 07, 2004 6:25 am
If the A/C system wasn't charged the defrost wouldn't use it anyway. And if you run the compressor without refrigerant to carry its lubricant, you'll quickly kill the compressor.
Posted: Sun Mar 07, 2004 6:27 am
by stant093
well i drove my 90 legacy with no AC compressor and never noticed anything...in this car my heater control panel is screwed up its stuck on defrost/floor all the time, i got to pick up a new one and swicth it out, but it was blowing heat on the trip back to my place so.....:shrug:
Posted: Sun Mar 07, 2004 7:11 am
by evolutionmovement
When the A/C works the defrost uses it to keep the air dry so in wet weather it doesn't add to the moisture on the windows. I've had mine removed for a few months now and there's no problem.
Posted: Sun Mar 07, 2004 7:21 am
by THAWA
ah okay
