Page 2 of 2
Posted: Tue May 25, 2004 5:42 pm
BAC5.2 wrote:Yea, I don't know how to do that, lol.
Page 74, section 2-7
Posted: Thu May 27, 2004 1:11 am
by BAC5.2
Well, it's futile, this thing is FUBAR.
Looks like I'll be going to the dealer to spend $362 for a new IAC valve. I should bend over and walk in backwards to make their job a little easier.
Posted: Thu May 27, 2004 2:32 pm
junkyard.......
Posted: Thu May 27, 2004 2:35 pm
by legacy92ej22t
It's going to be very hard to find an IAC valve for a turbo in a junkyard. Most yards want to sell the engine whole and not part it out. The IAC will definitely be considered an engine component.
Posted: Thu May 27, 2004 2:37 pm
Posted: Thu May 27, 2004 4:03 pm
by THAWA
the hell with those guys. Don't give them any business!
Posted: Thu May 27, 2004 6:25 pm
ok.....then these guys www.superrupair.com
Posted: Thu May 27, 2004 8:59 pm
by BAC5.2
To late, went to the dealership. $400 and it'll be there tomorrow or tuesday :(
Posted: Sat May 29, 2004 11:40 pm
by free5ty1e
I've just got to say, brake parts cleaner is the best friggin cleaning product known to man. If you can't clean it with brake part cleaner, you can't clean it. :D
Although, I woulnd't recommend cleaning anything like your teeth with that stuff. Although theoretically it would work quite well, I'm pretty sure there'd be some negative side effects, other than the taste. Which I'd imagine would not be all that pleasant.
OK back to the post topic. Where's this bitch located? I see the pic above but that's not in an engine compartment, it's on newspaper.
Posted: Mon May 31, 2004 4:45 pm
by BAC5.2
Look at your engine from the front of the car.
Look at the intake runner for the 3rd cylinder (I think that's #3). It's the one on the passenger side closest to the firewall.
There is a bigass black hose coming off of the pre-turbo resonator.
That hose leads to the IAC valve. It sits right off of the plenum facing the passenger side strut tower. It's got an electrical connector on top of it and a hose feeding it from an angle.
Posted: Mon May 31, 2004 10:47 pm
by free5ty1e
Ahh I see the light... thanks BAC... my idle's fine right now but at least I know where to look if it gives me trouble.
Posted: Tue Sep 15, 2009 4:28 am
by Rhinoculips
started a new thread.....port removed
Posted: Tue Sep 15, 2009 6:04 am
by log1call
The idle control may be fine, there may be an air leak which could cause the no boost and the irregular idling.
The problem with the O2 code too may not ne the sensor but something else that effects fuel mixture.
Those codes are just an aid to diagnosis and quite often don't mean the indicated item is faulty.
