Page 2 of 2
Posted: Wed Oct 26, 2005 1:50 am
by rallysam
dzx wrote:When its directly after the turbo. Like a couple inches. I would post a pic, but nasioc is down.
Are you talking about a stock-type sensor or wideband? The stock O2 sensor on an SS is located about 0.5" from the turbo.
Posted: Wed Oct 26, 2005 2:00 am
by rallysam
rallysam wrote:
Ok, well I guess I will give the stock location a shot and see what happens.
Update -
I installed my wideband in the stock location and it seems to work ok. Haven't noticed any problems yet.
I was getting AFRs of:
* 14.5-15.0 at idle or light cruise.
* 11.x at WOT
* readings all over the map during a gear shift (rich or lean)
I got those readings with the O2 input to the ECU disconnected, then I connected the "simulated narrowband output" to the ECU's O2 input and got basically the same readings.
AFAIK that seems right
Posted: Wed Oct 26, 2005 2:07 am
Sam,
What wide band do you have?
Posted: Wed Oct 26, 2005 2:30 am
by rallysam
Legacy777 wrote:Sam,
Zeitronix meter, which uses a Bosch sensor. Seems pretty cool so far... but I only have about 5 miles of experience with it.
http://www.zeitronix.com/Products/zt2/zt2.htm
Posted: Wed Oct 26, 2005 2:45 am
Thanks.
Looks pretty cool. Let me know how you like it.
Posted: Wed Oct 26, 2005 3:52 am
dzx - Yes, in principle having the sensor too close to the ports could make it read rich.
