Engine Pull and rebuild tips.
turboleg
Post by turboleg »
I got lost after the first three posts or so...I'm not the most excitable reader.
Great post doug!
I would like to add that when doing the AC (fully charged), as someone already said you can swing it off to the side. I think there is a mounting bracket for one of the hoses that can be removed. Gives you a few more inches of twist. Then she'll sit where you want it.
Another item, with my dad steadying the engine I was able to get the engine out of the bay without removing the radiator. Just have a big heavy guy that can hold the block up for you. Not that my dads fat or anything.... ;)
My radiator hoses were toast so I just lopped em off. Made it quick and simple.
But seriously you have to unplug the harness? ;)
- Findlay
http://www.toolsource.com
0perose
Post by 0perose »
0perose wrote:ok guys you'll probably kill me for this one...
what to do if we already took the torque converter off with the engine? :shock: :shock: :shock:
edit:
on the donor and swap car :(
the answer is play with the torque converter forever. you'll feel it when you've got it.
(jon drove it last night woooohooo!)
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
yazmo
Post by yazmo »
anyone know where i can find those $115 for gasket kit and $50 for ring set
jp233
Post by jp233 »
the only place you'll find prices that cheap is on ebay. a bunch of those Subaru engine items for sale on ebay appear to be the same seller with a few different usernames.
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
yazmo
about front speaker deep
Post by yazmo »
mine are blow and i wnder if these speaker would fit
or i need some spacer nobody know how deep the stock speaker are nobody wrote it.
JBL - GT5-652
Size 165mm
Nominal Impedance 4 Ohms
Power Handling, Peak 135W
Power Handling, RMS 45W
Sensitivity (2.83V/1m) 93dB
Frequency Response 55Hz – 20kHz
Mounting Depth 56mm
ThatZkid
Post by ThatZkid »
What is the special startup mode you were talking about? How do you activate it?
wtdash
Post by wtdash »
ThatZkid wrote:What is the special startup mode you were talking about? How do you activate it?
It's a procedure when starting a rebuilt engine or doing a head gasket.
Per DV's original post:
24- When you have replace the rings and/or pistons and/or heads, you need special start up mode to be in action.
1- remove the little areas above the fuel pump in back. Unhook those wire clips. This turns the fuel pump off.
2- Unhook the coil pack clip
3- Turn over the engine a few times to get oil back into the engine.
4- You DID add oil didn’t you?
5- Add the oil!
6- Repeat.
7- Hook all the clips back up. Start engine. Idle rev, Idle, rev. But not too long. Listen carefully. If you rebuilt or had the heads rebuilt, the engine is going to be noisier than hell. The tappets are starved of oil and it will take up to 5ish miles until they fill back up and start to be quiet.
8- Go to a remote area if possible and accelerate up to 50 and then let off the gas IN GEAR down to 30. Repeat for 5-10 times. This supposedly sets the rings.
Summary: This prevents a 'dry' start after a rebuild, and provides an initial 'break-in'.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
5- Add the oil!
LOL
RckyMtnLegacy
Re: Engine Pull and rebuild tips.
Post by RckyMtnLegacy »
Also if this has not been added to any list do not forget the drive plate and make sure your mounts are on correct just ran not this an hour ago
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
njdriver04
Post by njdriver04 »
Figured I would post pictures of the hoisting points. Was pretty much a breeze to take out.
'04 forester XT
Scoob Alumni
'94 TW, '96 L, '00 GT
Sublimejoe
Post by Sublimejoe »
Excellent info! Hopefully mine goes smoothly
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Sublimejoe
Also, care to share where you picked up the parts needed for rebuild? I see a few things on eBay, is that the best route to go?
Parts Needed:
Manual Cluster
WRXish
Re:
Post by WRXish »
edit:
I dont know about the rest of you, I'm making popcorn for this one lol 8)
WRXish
Re:
Post by WRXish »
edit:
5- Add the oil!
6- Repeat.
For the best break in I have ever heard of, try this process. What the guy says makes good sense.
http://mototuneusa.com/break_in_secrets.htm
I have used this basic process on every engine I have had built with good results. I am sure I will get flamed for this one...
