Wheelspin in an *AWD*
azn2nr
Post by azn2nr »
i still dont get how all 4 wheels have to spinn the same speed yet theres no power going to the back wheels on a normal well operating condition.
my wheels spinn up front too. but thats because i have a big turbo spoolin on me.
-jason
magicmike
Post by magicmike »
I dont mean to highjack this thread but I have a similar problem. I have noticed a diminishing rear end grip since I've been driving the car so I had it up on jack stands yesterday and stuck it in drive. I noticed that the left front wheel would spin and the rear right wheel was spinning. If I stopped the left front with my foot the right front would spin which is normal and if I stopped the right rear the left rear would spin. so I guess the diffs are working ok but I'm unsure how to check to see if the duty c selenoid is engaging and if the clutch is set right. I thought I read somewhere that there is an adjustment for it up high on the back of the tranny.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
gustavohuber
Post by gustavohuber »
if you're going to swap out struts, GR2s are wonderful, though in retrospect the AGXs might have been worth the extra bucks so I could have a real stiff back end for towing, or a real soft ride for picking my mom and grandma up from the airport.
ex-devastated ex-owner of the $5500 parts car!
free5ty1e
Post by free5ty1e »
In a 5MT, that FWD fusible link isn't active is it? I mean, the manual AWD tranny is just straight mechanical in its center diff (viscous coupling), no solenoid controlling the power, always 50/50 AWD (unless driveshaft disconnected)... correct?
On the same note, 4EAT's with their duty cycle-controlled rear power could potentially be rigged up with a driver-controlled center differential, could they not? Hmmm....
-Chris
91SS 4EAT stock, 200k mi
free5ty1e wrote:In a 5MT, that FWD fusible link isn't active is it? I mean, the manual AWD tranny is just straight mechanical in its center diff (viscous coupling), no solenoid controlling the power, always 50/50 AWD (unless driveshaft disconnected)... correct?
correct.
technically yes....but it's a little more complicated then sending a variable continuous voltage signal.
free5ty1e
Post by free5ty1e »
Interesting... too bad I don't have an auto to mess with...
-Chris
magicmike
Post by magicmike »
bump.....any thoughts on this guys
magicmike wrote:I dont mean to highjack this thread but I have a similar problem. I have noticed a diminishing rear end grip since I've been driving the car so I had it up on jack stands yesterday and stuck it in drive. I noticed that the left front wheel would spin and the rear right wheel was spinning. If I stopped the left front with my foot the right front would spin which is normal and if I stopped the right rear the left rear would spin. so I guess the diffs are working ok but I'm unsure how to check to see if the duty c selenoid is engaging and if the clutch is set right. I thought I read somewhere that there is an adjustment for it up high on the back of the tranny.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
