after swap, new engine can't idle
Natoe
Post by Natoe »
ive been researching around, trying to find this, and well, my car has been doing the same thing, starting but not idling.
my situtation is very different, i swapped the EJ22T into my impreza and wired it to the EJ22T ECU.
now it starts, i fixed the TPS problem (the wires change colors before they enter the ECU... black-white and white-black, (why???) anyways..
so now it will start and rev a bit but still wont idle, im trying to check the IAC but i need to know what the plug pinout is! i cant open josh's site since this computer is too slow... :( or id get the info there
looking at the IAC Valve:
( 3 | 2 | 1 )
3 is a white wire, (closed end)
2 is yellow/red stripe (power)
1 is a black wire, (open end)
can somebody verify this for me? i just guessed on those, and need to make sure it is right! thanks!!!
You can't open this jpg?
Looks like you have things correct
http://www.main.experiencetherave.com:8 ... C_diag.jpg
Natoe
Post by Natoe »
AWESOME i can see that one. thanks!
yeah, i have it backwards, the black and white are switched on the impreza, just like the TPS was!! what the heck subaru??
atleast i found out what was wrong and can fix it! thanks for your great site, i finally got on a computer i can read it. the FSM's have helped me a lot!
