Page 2 of 2
Posted: Fri Jan 20, 2006 8:52 pm
by subawhatsubawho
Maybe you could upgrade to aftermarket terminals?
When I get my bigger amp I will be installing a yellow top but I am going to switch the terminals out so I can run 1guage wire on the + side and do some sort of grounding mod on the - side.
I will also be adding a digital display cap.
I Don't know if some of you know this but if you have a battery with top and side mount terminals and you are using the top terminals to power your car, you shouldn't hook up your high drain items (amps and the likes) to the side terminals.
I was watching a car customizing show a while back and there was an optima rep on there talking about it. He didn't get into detail but just said that with all the Optima batteries being put into custom audio set-ups the people should know what can and can not be done with their batteries.
I hope this helps.
Posted: Fri Jan 20, 2006 9:06 pm
by Splinter
Terminals or rings?
I looked at after market rings, but Im not exactly sure how I'd replace the stock ones.
Posted: Fri Jan 20, 2006 9:26 pm
by subawhatsubawho
I plan on cutting the old terminal ring off, stripping the wires, and installing them in the new terminal. The one I am purchasing has (1) 1 guage terminal, (1) 4guage, and (4) 8 guage connections.
Everything I need to do the swap and leaves room for expansion.
Posted: Fri Jan 20, 2006 9:31 pm
by Splinter
Solder the old wires to the new ones?
Posted: Fri Jan 20, 2006 10:10 pm
by subawhatsubawho
They clamp in.
Posted: Fri Jan 20, 2006 10:14 pm
by Splinter
oooo
Pretty
Posted: Fri Jan 20, 2006 10:23 pm
by subawhatsubawho
There is also one that has a digital volt meter built in.
Posted: Sat Jan 21, 2006 12:46 am
by Splinter
Picked one up today, fairly basic, just a 3 terminal dealie.
1 4 gauge, 2 8 gauge I believe
4 gauge - Stereo
8 gauge - alternator
8 gauge - car systems
Posted: Sat Jan 21, 2006 1:52 am
by subawhatsubawho
Nice!! I hope it works out for you. Maybe you could do a write-up....with pictures.
Posted: Sat Jan 21, 2006 2:00 am
by Splinter
It does not work out for me.
The starter cable is about 2 inches too short... and Ive already hacked off the connectors
I plugged into into the inline fuse I use for my stereo, and it starts the car, but now I have to drive back into town and pick up a longer starter cable... goddamn.
How hard is it to remove the old one, cuz Im gonna have to do it in the parking lot
Posted: Sat Jan 21, 2006 3:26 am
by mikec
Its a 12mm nut and lock washer under a rubber boot on the back of the starter. Kind of a pain to get to, but possible... If you've got a ratching wrench, that'd be ideal.
by subawhatsubawho
Laurel is having the same problem with her optima battery.
Starter cables aren't hard to install at all.
Posted: Mon Jan 23, 2006 10:13 pm
by Splinter
Josh, think I should buy a new alt belt while Im at it?
Posted: Tue Jan 24, 2006 8:01 pm
That's entirely up to you. If your old belt is fine, then you can use it. If it's not...replace it.
It wouldn't be a bad idea to replace it, so you have everything new.
Posted: Fri Jan 27, 2006 4:26 pm
by Splinter
Do you think I need to upgrade any other wiring than just a strap straight from the alt to the postive terminal of the battery?
Posted: Sun Jan 29, 2006 3:26 am
Not really. I just added extra ground wires from the chassis & starter. If you haven't done that yet, do that.
I'm probably going to go back and do a single point ground at some point.
