206er wrote:heaven help you if it isnt enoughYukonart wrote:555BCTurbo wrote:I might have to go the external gate route when I get the Holset conversion done on my SS...although I figure that the Holset wastegate will work for 25 or so psi...I was going to say, that Holset setup should already be able to handle the power levels you're looking for, Nick.
now keep in mind that holset wastegates are intended for diesels, which dont have the exhaust energy of gas engines. also, the HX35 has a convoluted wastegate setup where the wastegate port is only in one runner of the turbine, which causes boost creep.
so, external may be the way to go.
nick, what holset did you have in mind? HY35 or HX35? an HX35 with a properly designed twin scroll split header would be sweet.
gotta love the fact that holsets make full boost below 4000 in higher gears too...![]()
I'm thinking of going with a holset but I dont know if it is such a good idea with the bottom end I will run, 350BHP is my goal.
sammy, is that an audi 5000t wastegate? those are a very good unit. 600hp capable, durable, cheap. but I'm sure you knew that.
what did you do for flanges?
Trust me, I know A LOT about using Holsets on gas motors...I wouldn't just try it if i didn't lol
They are a very common upgrade for 2.3T Fords, and some good friends of mine build equal length, twin scroll stainless headers for them, so I am pretty well versed in setting them up correctly.
I do actually plan to run the HY35 or a HX35 with the splitter machined out of it, as I will not be running twin scroll initially.
I will be doing some stuff with a Perfect Power and DIS2 to help keep the Holset spooled as well, as it could become quite a lag monster
My power goals are at least 350awhp.
