Gear Ratio and LSD info
Hey JOsh I was just doing some work to the mid late 90's Legacys with the 2.2 Na, for the 5mt's the final drives are 3.9, where the 2.5 were 4.11. I have had a few this week from 94-99 and the FSM was consistant to the above gears over that spread of years. Just thought I's add that...
2011 Mini Countryman S All4
1970 Honda Ct90
1970 Honda Ct90
I don't know if you guy have been reading up on my posts over on NASIOC or RS25.
These are ALL 5-SPEEDs.
90-94 Legacy 5spd: 4.111FD
95-99 Legacy 2.2L; excluding 2.5L: 3.900
96-99 Legacy 2.5GT/Outback 2.5L: 4.111
93-95 Impreza 1.8L: 4.111FD
96-01 Impreza 2.2L: 3.900
98-01 Impreza 2.5L: 4.111
02-03 Impreza 2.5RS: 4.111
04+ Impreza 2.5RS SPORT: 4.111
02+ Impreza 2.5TS/OBS: 3.900
04+ Impreza 2.5RS(non-sport): 3.900
This is from my reseach thus far.
Mod edit: Changed years to 1990-1994 Legacy 5spd
MY99 GF4 5spd DIY Modified
FD on a 1990-94 5MT fwd is 3.70. Turbo 5MTs are 3.90.
You should be 4.11 I believe. Someone will pipe in and correct me if I'm wrong but I know that the 5sp AWD NA's are 4.11 and I'm very positive you are too.
On the back cover of the rear diff, likely under some road grime, is a ~1"x2" sticker that will verify that for you. Just wipe off the back and take a look.
Lee
I believe this thread is missing the most important information of all, a differential code translation matrix.
Often you get a differential and you can't be sure what vehicle it came from. Even then you never know if it was swapped at some time. Even with the older style units the foil sticker is sometimes missing and you are left to guess. I searched high and low for this info and so far i haven't found it. Instead I went out and manually measured a bunch of differentials myself.
Code - axle type - LSD? - size - ratio
HB - female axles - open - R160 - 3.9
BK - male axles - LSD - r160 - 4.11
EF - male axles - LSD - r160 - 3.54
TR - male axles - open - r160 - 4.11
From what I can tell all differentials at least from the first generation legacys have this code painted on them in multiple spots.
I also posted this information on nasty cock, see this link http://forums.nasioc.com/forums/showpost.php?p=22235523
Can we modify the first post to start to include these codes?
BTW, if anyone cares my frankendiff has been working for many years without issue. I took a 4.44 LSD and a 4.11 open differential and put the VLSD carrier into the 4.11 case.
I made a mistake on the last post (a very fuking time consuming mistake). The TR is actually an open differential.
Also on a different not this page has many transmission code numbers and specs!
http://spda-online.ca/modules/tinyconte ... tc_28.html
fishbone79
OK, according to this (pdf) the 1995 Legacy AT has a 4.111 FD, while the MT has 3.900 FD... Exact opposite of the first gens.
Thanks to kimokalihi for those manuals, see this thread for the others: http://bbs.legacycentral.org/viewtopic.php?t=40325
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
Re: Gear Ratio and LSD info
http://www.gearhack.com/myink/ViewPage. ... on%20Chart
This one has a ton of gear ratios. Doesn't do automatics though.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
WRXish
i need a compatible replacement tranny for my 91 legacy l, given that the rear end is a 4.11 what transmissions are compatible?
All the 4.11 transmissions will work, until they got rid of the speedo gear in the transmission itself. So anything prior to 05 for legacys, and prior to 08 for impreza. If you are intending to keep the cable actuated clutch, then stick with 90s 4.11s for ease of swapping.
WRXish
Many thanks Mike, anybody you know have a good one laying around they want to sell in decent shape?
The newer "phase 2" transmissions that appeared in the late 90s/early 2000s have twice as many bolt holes as the older stuff, but they still mount and bolt up just fine. That's what I'm using on my 92 Legacy, a 99 Impreza 8-bolt transmission.
I have a mt5 1993 legacy ss with a stock 3.90fd open diff. Can I swap in a 3.90fd 91/92 legacy ss vlsd using the rear axles already on my car?
If not, how hard is it to find the correct rear axle stubs? or is it possible to open up the axle housing and put the vlsd differential case into my open diff housing?
1993 Legacy SS 5mt, just getting started
1. Only 91ss got vlsd, and 2. You need to get that Diff with the Stubs attached. Without the "unique to 91 VLSD diff only" stubs which are long out of production, the diff is useless. 3. Standard 90-94 legacy axles work.
Someperson
94gt is 4.111 correct?
93 Winestone TW project
