I was thinking something like that, but I know that you know FAR more about this stuff than I do....
I may do that.
Any particular rating I should get? I've seen some on eBay that are meant for up to 25 amps.
Must install panic button
IronMonkeyL255
IronMonkeyL255
And what you mean is bridge a wire between the ON and START wires with the switch in the middle? As in without cutting either wire?
Just trying to be thorough here.
Rio Red '91 Legacy SS
Yes, that is what I mean. Or you can cut the START wire if you like; if you do, the ignition switch will never work for starting the car.
25A would probably be okay (the starter solenoid shouldn't draw anywhere near that much current), but put a 25A fuse in series with it. The existing fuse is rated at 45A, so it could allow enough current to flow through the switch to cause a fire.
IronMonkeyL255
IronMonkeyL255
Well, my 'rents have agreed to pay for a new ignition switch, so I'm gonna do that.
Burned the shit out of my arm trying to get under the i/c to jumper the starter to the battery.
