Page 2 of 2
INTERCOOLERS
Posted: Tue Oct 01, 2002 2:12 pm
by FREDERICK.WHITMORE@CN.CA
Adam- Would you be able to find out what the part # is? How much are you
selling the used 93-96 intercoolers for?
Fred
INTERCOOLERS
Posted: Tue Oct 01, 2002 3:32 pm
by Z1Auto@aol.com
I would need to look into it..do you meant he Subaru part # I assume
Used IC's I nned to look into...about 4150 or so as I recall, and this includes the piping. We can also supply the Samco hose kit as well for around $65.00 (I just did mine yesterday)
Adam
INTERCOOLERS
Posted: Sat Oct 05, 2002 11:57 pm
by alexius ludeman
> On the 93-96 IC, you need to cut off one of the mounting tabs (drivers side)
> in order to have the coolant tank fit in the OEM location. I chose to leave
> the tab and simple rotatwed the coolant bottle 180 degrees so though it now
> only has one mounting screw (vs 2 stock) is holds well and there is room
> enough for the IC mounting on either side
> On a 2002, the coolant tank will definately need to be moved...not hard to
> do, just another step!
I have some pictures up of my install. I opted for removing the tab and leaving the coolant tank in place.
http://lexinator.com/cgi-bin/photo/inde ... ntercooler
good luck
lex
INTERCOOLERS
Posted: Sun Oct 06, 2002 10:17 am
by Z1Auto@aol.com
thanks Lex!
