Mountain Wagon Project aka Junkyard Dog
Re: Mountain Wagon Project aka Junkyard Dog
vrg3 wrote:Woah, hallie, good point! I totally missed that! You could install the crank pulley bolt without the crank pulley, though, right?
It wouldn't necessarily be game over -- it's a non-interference engine -- but it would be a mess for sure.
No the crank pulley bolt only holds the pulley on and won't stop the cam belt gear from moving.
If the cam belt gear moves it could rub against the case and damage other things as well as break. It may not be game over, but who knows.
The thing I'd be concerned about is damage to the crank keyway. If it is damaged and you continue to drive the engine that way, especially with the crank pulley off, it will more than likely wallow out the key hole, then the crank would be toast....and essentially the engine would be toast without a rebuild.
You can thread the crank pulley bolt down far enough to clamp the sprocket down. After doing a timing belt job I do this so I can do a compression test before reassembling the timing covers and main pulley.
There is a little lip between the sprocket edge and the end of the crankshaft......or at least it's been like that on every timing belt I've ever done. So tightening the crank pulley bolt won't do anything to keep that sprocket in place.
Here's a pic
http://www.main.experiencetherave.com/s ... P_2702.JPG
Oh, I see; you're right. I must have just gotten away with it for the compression testing.
SWRT
Post by SWRT »
What about washers?
A few different sizes. Ones that run over
the key getting smaller til you hit ones that
just run around the bolt. It'd be difficult to
find the right sizes, but it'd be safer than not
having them...at least I think it could work.
Not in a pinch though unless you're just loaded
with tools haha
You'd have to get larger ones to fit over the woodruff key or notch the washers.
northcoast
Post by northcoast »
I put it back on and drove it home. When I got home I replaced it with a mint one I had on my spare engine.
I picked up a 2.5 short block the other day and am getting ready to do a Frankenmoter. Just waiting on new gaskets to show up. Lift should be ready soon as well!
Lifted 91 LS Wagon : SOLD
87 GL-10 Turbo : SOLD
Lifted 97 Impreza OBS
98 Impreza OBS RallyX / DD
SWRT
Post by SWRT »
Hey, glad it held all the way home :D
I'm guessing higher compression?
northcoast
Frankenmotor almost complete. I would have finished it last night except I couldn't find the tensioner mounting bracket. A quick run to PnP after work to grab another and then I can put it back together. I will drop it in this weekend when I install the new lift kit.
northcoast
Frankenmotor and lift are in. I love the added power. Here are a couple pics of the lift.
I put in some quick release pins for while I'm on pavement. She's much more stable with them in.
Next on the list...
1. Re-do the steering linkage.
2. Fab and install my skid plate.
3. Dual Range swap.
4. Exterior lighting and a new rack.
SWRT
Post by SWRT »
I'm pretty freakin jealous of this thing. How much did you say
the 4" lift was?
northcoast
SWRT wrote:I'm pretty freakin jealous of this thing. How much did you say
the 4" lift was?
$600
www.sjrlift.com
SWRT
Post by SWRT »
Dang. I'm cheap. I'm gonna try and replicate it
from the pictures if I can find someone with a
welder haha
SWRT wrote:Dang. I'm cheap. I'm gonna try and replicate it
welder haha
Would be relatively easy with a section of 2X3" square tube and something to cut it with.
SWRT
Post by SWRT »
Well, I was thinking of different designs yesterday
and how to make lift supports with extra bracing
and buffering to make sure they can take impacts
and heavy off-road driving at speed without folding.
northcoast
Most of the pieces are fairly easy to fabricate. The two hard ones are the two that take the most pressure, anti-lift at the front and the rear trailing arm. Those two pieces were the whole reason I purchased the kit.
SWRT
Post by SWRT »
Yep. I noticed those were gonna be the biggest pains.
I'll have to research more into it when I get time.
