Please Help!!! Auto Trans Problems!!!!
pnw13black
Re: Please Help!!! Auto Trans Problems!!!!
Ok so I have read it a few times and I have a question. On the Neutral switch wiring im a bit confused. So you cut B15 off the manual cars body harness which is a two wire connector consisting of termnal 3 and 1, then you cut the old automatic trans harness off the actual transmisson number B15 which is a 12 wire connector. Then you wire togther the manual 3 and 1 termnal to the automatic 4 and 1 termnal. My questions are does it matter which one goes to what and in the photo why is it showing 4 wires off the manual trans harness side? Shouldnt there just be two??
92 n/a leggy
5 speed swap
ACT Pro Lite flywheel
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
RIP- Frankenmotor 2.5
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
JC/Legacy777 gave me this info during my swap:
TD
I didn't cut the AT connectors on the chassis side, but did cut off one of the connectors from the AT transmission, as noted above.Really you need to answer one question....do I care about having the starter interlock circuit wired up so I can't start the car without depressing the clutch all the way in? If the answer is "I don't care about the starter interlock circuit", then the wiring is very easy.
You need to jumper pins 11 & 12 on the B15 connector that plugged into the trans. This can be done by cutting off the connector on the transmission and then using a crimp connector to connect those corresponding pins.
You need to wire up the reverse lights & neutral switch from the MT. If you can get a hold of a chassis side connectors, you can again wire these guys up through the transmission plug you cut off the AT. This would make all the connections plug & play.
If you can't get the MT connectors for the neutral & reverse lights, just use some waterproof spade connectors connected to the AT plug you removed from the trans.
The only remaining items that need to be addressed is to snip the one wire I talk about for the neutral switch. I believe it's pin 10 on the B58 connector. It's the blue connector on the lower left side of the driver's dash.
You need to remove the TCU, remove key interlock controller (as you mentioned), and you need to snip the wire going to the MT/AT identifier pin on the ECU.
That's it....there's really not much to it.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
pnw13black
The 12 wire connector i need off the automatic trans harness is the one that goes to the valve body (drivers side)
I don't want to make a mistake.
92 n/a leggy
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
To answer you question above, no it doesn't matter which wire goes to where. It's just completing the circuit, and the electrons can flow either way through the switch.
pnw13black
Ok so i got all my parts in today, im gonna pull the automatic today but i have a question. Why do i need to jump the park wiring? I should only need the neutral right?
92 n/a leggy
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
pnw13black
Well i got it all together, works great!! Love being able to shift.
92 n/a leggy
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
Glad you got it fixed.
pnw13black
hahah i knew something was going to go wrong...so I forgot to pull the shift lock and now my key is stuck in the ignition. I pulled the shift lock box but its still stuck....any ideas on what i should do?
92 n/a leggy
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
pnw13black
Nevermind, I found the orange tab under the steering column. All is good now haha. Oh and I followed the wiring to a T but my reverse lights dont seem to be working. Not that big of a deal just curious, did i miss a step?
92 n/a leggy
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
5 speed swap
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
Hmm, not sure. If you wired everything correctly and it still doesn't work, I'd verify that you have 12v on one of the wires going to the backup switch. You could try jumpering 12v to the wire going to the reverse lights to make sure they work.
