Re: Codes 17, 22, and 41
Posted: Sun Jun 15, 2014 4:14 am
Ok, so to recap, you now have no codes, but have a high idle, is that correct?
Have you performed the d-check with the green connectors?
If you've done that, everything is good there, and still have a high idle check if your TB has one of these bypass screws on it:
http://www.main.experiencetherave.com/subaru/images/TB/
The other thing to check would be the TPS to make sure it's adjusted properly. Have you adjusted or does it look like any of the throttle stop screws have been messed with?
Here are the instructions for adjusting the TPS and should be the only adjustments you make:
http://www.main.experiencetherave.com/s ... sting3.jpg
You can see the pin numbers for the TPS in this first scan:
http://www.main.experiencetherave.com/s ... sting1.jpg
