Rob's 4to2 Igntion Converter
Re: Rob's 4to2 Igntion Converter
so i maybe mistaken but this will work on the stock EJ22T?
Please read the 1st post on page 1.SILINC3R wrote:so i maybe mistaken but this will work on the stock EJ22T?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Yes it will. Once installed it will allow either the EJ22T ECU or the EJ20G to be plugged in without changing any wiring. That was a design goal of mine. The only reason to use it with an EJ22T ECU is in preparation of switching to an EJ20G ECU, or if you were running an EJ20G and wanted to quickly and easily revert back to stock. Hope that makes sense.SILINC3R wrote:so i maybe mistaken but this will work on the stock EJ22T?
-Rob
thanks for the quick reply, however still a little confused. if you have a stock EJ22T why would it be in preperation for the 20G ECU, is it because this is only meant for running bigger injectors and such. Also I do have a 20G motor but dont mind keeping it stock 22T ECU for the time being I guess is my confusion. Might this work on the 22 N/A, have one of these as well. Look forward to seeing it all put together just curious.
I think you might be missing the big picture. Some sort of ignition conversion is required to run an EJ20G ECU with the EJ22T ignition setup. You would only be interested in my converter if you have plans to switch ECUs types at some point. Since it is compatible with both ECUs without rewiring, you could install the converter ahead of swapping ECUs in case you were not ready to swap right away for whatever reason. Re-read the first post on why this is necessary.
-Rob
-Rob
Hi,
Short answer: Yes, EJ20 ECU for more tuning options that work w/the EJ22T.
Longer:
The EJ20 ECU has many more tuning options, including Rob's tune. Since the EJ20 ECU covered multiple years and markets - Europe/UK, Aussie, JDM - there are tons more and therefore much more for tuners to tune for.
And since Subaru was kind enough to share wiring pin-outs between the early Legacy/WRX/STi platforms there are only a couple changes to be made between swapping out ECUs...and w/this adapter it'll be plug-n-play.
The stock EJ22T ECU has had very limited support from the tuning community due to the short life-span and limited # of cars sold. Besides the Revtronix chip and piggy-backs, such as the PP6/Greddy/etc., there isn't much.
The Autronic standalone Mr. kleinkid uses is a great platform, but big $$.
TD
Longer:
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
I got some road testing in this weekend with the converter and the EJ20G ECU on Drew's car. I installed a watered down version of my tune (max boost @12psi) as there is no boost gauge yet. Short story is that it runs fantastic. This bitch is done! I have sent the PCBs out for fab and have parts ordered. Once I get the final BOM figured out and an idea how difficult it is going to be assemble with all of these surface mount parts I will have pricing info.
-Rob
-Rob
Sounds good rob, thanks for putting forth so much effort for us old school guys.
scoobylover57
Sounds awesome! I'm ready to buy one.
-Nick-
91 lsi with ej22t swap. work in progress. Sold.
92 SS 5spd. stock. Sold.
94 TW. 6 spd. V2 sti ra ej20g. 550's. rob tune.
94 SS 5spd. stock
94 SS 5spd. stock
farfrumwork
Sweetness!
I'll buy a ECU/converter when you have the parts in-house. Do you have a spec sheet for the ECU's so we can detail engine builds (turbo/injectors), and also pick rev limits, launch control settings, etc...?
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
dscoobydoo
Realize that without a dyno and you there on site for tuning, these tunes are going to be pretty generic.
But Rob has taken quite a bit of time to give us all another option for tuning that does not cost an arm and a leg.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
I want one when there ready, and can i get a ej20g sti ecu?
SA (STi chipped) - 1993/1994 STi 13.64psi
SB (STi chipped) - 1993/1994 STi RA 13.64psi
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
bmxkelowna
the SA and SB ecu's are both 4 plug so i think it would be okay, rob would know for sure
More of a tune question, then a converter question....In any case, I can put any stock ECU image you want onto a chipped ECU. Frankly my tune is better than all of them, so I don't really see the point. Alternatively, you could buy any used EJ20G ECU version as well. It is up to you.Rubasu wrote:I want one when there ready, and can i get a ej20g sti ecu?
bmxkelowna
i think he was just asking if you could chip and tune those ecu's
oh ok. If that is case, yes. I can chip any ej20g WRX ecu. There is no reason to pay more for an STi or RA any special version. They have identical electrical hardware and once chipped, it doesn't matter what they originally were.
-Rob
-Rob
That's awesome Rob! I'm about to send you an email so we can get started on talking about a setup for my car.
LookAsubie
Awesome news, Cant wait to purchase this stuff and get all my parts into my car
1992 legacy SS 5mt, Winestone Metallic.
ya that's the info i wanted . The Q was because i was going to get an ecu soon, to go with the converter.
Ok, just buy the cheapest EJ20G WRX ecu you can find. If it is in question, send me a PM with the ECU info and I can confirm it will be ok.
-Rob
-Rob
ok thanks, what years?
93-96, 4-plug style
bmxkelowna
any of these ecu's are useable
U8, 2C - 1993/1994 WRX - 11.47psi
W6 - 1993 WRX RA - 11.47psi
W9 - 1994 WRX RA - 11.47psi
SA (STi chipped) - Ver1 STi (Sedan and Wagon) - 14.94psi
SB (STi chipped) - Ver1 STi-RA - 13.64psi
SC (STi chipped) - SAME AS Z4 - Ver2 STi Wagon - 12.78psi
Z4 - 1995/1996 WRX - 12.78psi
Z5 - 1995/1996 WRX-RA - 12.57psi
6K - Ver2 STi Sedan - 13.34psi
7K - Ver2 STi-RA - 13.19psi
Prodrive UK ECU (Prodrive Chipped) -- SAME AS 6K - 13.34psi
1C, 3B, V9, V5 - All WRX Wagons 10psi, dropping to 6.8psi
V7, 7D, 6D - 1993 to 1996 UK/Euro 11.47psi
and like rob said, once its chipped and tuned they are all the same so there is no point paying more money for an sti one over say the typically cheap U8 wrx ecu
Thats what i found too, thats why i was asking.And thanks again rob for ur hard work alot of us really appreciate it.
I handed off the test mule still running my prototype back to Drew for some unbiased opinions on how it runs. I'll let him elaborate if he likes, but the report was that as far as the ignition system goes, it runs as stock.
Ok, parts and PCBs came back last week. I worked on assembling the first one. I did miss one trace on the board, so the first batch will need a blue wire...damn. I am working on a small test bench in order to verify each one build actually works. I also need to pick up some more wire, then I think I will be ready to take orders; maybe as soon as next week. I have settled on prices;
Converter = $90 ($70 for those already running my tune)
Converter + Tune = $350
Converter + EJ20G + Tune = $455
Shipping in the US is inclusive.
After the first one is finished, I'll post a pic.
-Rob
-Rob
