Knock sensor code. cant clear it. bad knock sensor?
Re: Knock sensor code. cant clear it. bad knock sensor?
90-91 metal maf 91-94 turbo legacy as well. As long as its the metal hitachi, you're good.
Sent from my SGH-T889 using Tapatalk
aaronllewellyn
Post by aaronllewellyn »
cj91legss wrote:90-91 metal maf 91-94 turbo legacy as well. As long as its the metal hitachi, you're good.
I'm going to have to get one from a forum member there are no Tlegs in NY junk yards, only tons of outbacks
aaronllewellyn
I'm probably going to trade the car for a Chevy 305 swapped Volvo 740 wagon.
I cant pass that up.
with only 12k on a reasonably built motor.
http://ithaca.craigslist.org/cto/4522748454.html
robertpaige
Post by robertpaige »
Bummer city!
aaronllewellyn
robertpaige wrote:Bummer city!
I suppose but this car's been through so much I spend more time fixing it than driving it, it's close to being reliable, but this MAF put me over the edge.
Try to find an enthusiast who is willing to nurse her back to health. Your subie deserves not to be put out to the pasture, since it's so close to running well.
Congrats on the volvo though, I almost pulled the trigger on a 940SE recently. Turbo, IRS with factory LSD, auto :(, low miles, great shape for $800. Ah well.
aaronllewellyn
mike-tracy wrote:Try to find an enthusiast who is willing to nurse her back to health. Your subie deserves not to be put out to the pasture, since it's so close to running well.
you really should have! the Turbobricks/ older turbo Volvo forum is strangely more active than legacycentral. it's making a comeback.
aaronllewellyn wrote:There are no turbo legacy in Binghamton NY, I've seen one other up here in my life and it had out of state plates.
could leaving the stock boost solenoid connected prevent it from running properly.. even if there are no hoses attached..? either way it has to be still in some sort of limp mode...
Well, maybe I've connected the knock sensor wire incorrectly, I have this poorly drawn diagram of the pinout I'm just curious to know if this is the right side of the plug to be looking at when you wire it, way it's wired right now is opposite to the diagram, maybe me assuming the black wire was the ground was incorrect?
Your diagram is incorrect. The numbers should be swapped on the connector. The numbering that is presented on all the diagrams references things as if you are looking directly at the ECU. So the chassis side ECU connector numbering would be opposite. I go into more detail in this thread.
http://bbs.legacycentral.org/viewtopic.php?f=19&t=51176
aaronllewellyn
thanks, sadly I checked and noticed It was correct after making sure it was as you described, I guess I just await the MAF, we'll see.
Well, let us know if the MAF sensor fixes things.
aaronllewellyn
Legacy777 wrote:Well, let us know if the MAF sensor fixes things.
if it ever arrives in the mail.
jessman1942
Post by jessman1942 »
did you ever fix you problems with the knock sensor ?? still have the car???
88 Honda civic wagon B20VTEC SWAP-RIP
85 Subaru loyal sedan-SOLD
95 Subaru impreza $500 BEATER-SOLD
91 Subaru legacy SS jdm ej20g swap
CHECK OUT MY ej20G BUILD HERE>> viewtopic.php?f=25&t=53766
