Page 3 of 3
Re: Misfire and stuttering under load.
Posted: Tue Jul 04, 2017 7:16 pm
by beatersubi
Well... she runs smoother and the hesitation seems to be gone after swapping out the coil pack. I just filled up, so I'll be able to see if my mileage went back up from the ~21-23mpg it was down to.
Oldandslow, did you install a new replacement coil pack?
Posted: Thu Jul 06, 2017 12:42 am
by 93.20G.5sp
beatersubi wrote:Well... she runs smoother and the hesitation seems to be gone after swapping out the coil pack. I just filled up, so I'll be able to see if my mileage went back up from the ~21-23mpg it was down to.
Definitely keep us updated, I have the exact same issue as y'all do, if I keep it under 10% throttle or so it'll rev to redline however. I took the coilpacks out and redid the wiring (GD coils) to them, it seemed to help some. The coils looked ok but maybe there was hairline cracks.
Posted: Sun Jul 16, 2017 6:29 am
by beatersubi
Filled up today to find that the car got 25.4MPG. Not the best that she's ever done, but a definite improvement. And the with the stuttering/hesitation gone when she gets into positive manifold pressure, I'm less hesitant to take her there.
Posted: Tue Jul 18, 2017 6:56 pm
by subiedoutlegacy
beatersubi wrote:Filled up today to find that the car got 25.4MPG. Not the best that she's ever done, but a definite improvement. And the with the stuttering/hesitation gone when she gets into positive manifold pressure, I'm less hesitant to take her there.
I read through the whole thread and realized that you never smoke tested the car. I had almost the same exact issues which is on here due to the intake manifold being cracked. Try smoking the car to see if there is any leaks.
Thought I would throw that in since I experienced a lot of issue like you and would of never thought it was my manifold (I even changed the manifold gaskets and didn't see the crack
This is my thread with similar issues:
viewtopic.php?f=5&t=53649
Posted: Tue Jul 25, 2017 12:36 am
by beatersubi
subiedoutlegacy wrote:beatersubi wrote:Filled up today to find that the car got 25.4MPG. Not the best that she's ever done, but a definite improvement. And the with the stuttering/hesitation gone when she gets into positive manifold pressure, I'm less hesitant to take her there.
That's a good suggestion. But I think replacing the coilpack has resolved my issue. This might help the OP, though. Oldandslow, did you ever check for leaks under positive manifold pressure?
Posted: Mon Sep 18, 2017 11:24 pm
by Oldandslow
Well I finally figured it out. Took it to a local speed shop and the dude there was super knowledgeable. Had a whole table of spare parts ready for when I got there. He threw a used maf on and voila! Car runs great now! Check engine light has gone off as well and stays off. It's still slow haha but at least the drive-ability is there. Now the only thing wrong is my speedo reads 12 mph too fast. At least that's not a huge issue.
Posted: Mon Oct 09, 2017 4:41 pm
by beatersubi
Oldandslow wrote:Well I finally figured it out. Took it to a local speed shop and the dude there was super knowledgeable. Had a whole table of spare parts ready for when I got there. He threw a used maf on and voila! Car runs great now! Check engine light has gone off as well and stays off. It's still slow haha but at least the drive-ability is there. Now the only thing wrong is my speedo reads 12 mph too fast. At least that's not a huge issue.
Good to hear.
