93 Legacy GT-S2 Wagon (BC-BF EJ20 turbo)
Posted: Thu May 02, 2002 12:49 am
Josh, John, Ian, Sambo - many thanks for the advice. I can see that there
are some real enthusiasts out there, good stuff.
Looks like my plan of attack is:
New Springs and Struts
K&N Flat Filter or similar
2.5" exhaust
Snorkusectomy, maybe (what a brilliant idea though!)
Im gonna need a pay rise...
Josh could you confirm what you are saying about the MAF sensor? I read it
from your email, that it will be AOK if I stick to the standard air intake
box (even with a snorkusectomy performed) but can be dodgy with an open
style filter? I take it that Open style means the cylindrical type, rather
than flat filter.
Oh and one other thing. My auto box has a "manual" mode, a button you push
on the gear lever which apparently holds in 2nd and 3rd gears. I cant see
the difference between just moving the gearstick to "2" or "3", which
should hold the gear, and the manual mode. Any ideas?
cheers
Paul
"Josh Colombo"
<josh@surrealm To: <BC-BFLegacyWorks@yahoogroups.com>
irage.com> cc:
Subject: RE: [BC-BFLegacyWorks] 93 Legacy GT-S2 Wagon
02/05/2002
14:54
Please respond
to
BC-BFLegacyWor
ks
Good things being mentioned here.....I'm mainly going to comment on the
cautions. If you do have the Twin Turbo, do not do anything or much to
it. The small turbo is a roller bearing turbo, and is easily over
spooled, and can cause like Ian said, need to be rebuilt.
As for intake....I'd really and highly recommend you just get a K&N drop
in panel filter, and remove the snorkel stuff in the fender.
I have replaced a MAF sensor $300 US. NOT CHEAP....worst thing is it
slowly went out...intermittently I would loose power....I chased this
problem for over a year. Second reason to leave the intake
alone.....you will be sucking hot air from the engine bay....plus you
will get more turbulent air, and MAF doesn't like that as much.
Check out this thread
http://pub1.ezboard.com/fultimatesubaru ... rationofsu
barus.showMessage?topicID=4495.topic
I just wrote this up like 10 minutes ago. It talks about me putting my
stock box back on and how much of a drastic improvement in engine idle
and smoothness there is. I also mention what I am going to do to
hopefully increase air flow for the stock box.
Instructions on how to remove the snorkel and such from the fender well
can be found here
http://www.remarcable.net/misc/legacy_o ... kusectomy/
Hope that helps.
If you have any questions, just holler.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
Sent: Wednesday, May 01, 2002 8:51 PM
Subject: Re: [BC-BFLegacyWorks] 93 Legacy GT-S2 Wagon
If thats the twin turbo be very carefull when considering a larger
exhaust.
I have a friend outside of melborn who had one with a 3" exhaust from
the
turbo back and the first turbo would always fail and have to be rebuilt.
Everyone I've herd from says don't go bigger than 2 1/2" all the way
back.
Ian
>From: paul.travers@vodafone.co.nz
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Subject: [BC-BFLegacyWorks] 93 Legacy GT-S2 Wagon
>Date: Thu, 2 May 2002 11:16:58 +1200
>Hello
>I recently saw the light, and traded in my 1992 Honda for a 1993
Japanese
>Spec. GT-S2 Wagon, AWD 2.0L Turbo, 4-Speed Auto. It is completely
factory
>standard, and while I am (extremely) happy with the engine performance,
I
>am looking to slightly modify the suspension and/or wheels/tyres setup
to
>improve the handling. Wheels are standard -- 205/60/R15.
>Does anyone have any advice on tightening the handling for wagons? Not
>wanting to race or anything, just reduce the body roll (which can be
>alarming on tight/windy roads, compared to my honda hatchback which
took
>corners nicely at speed).
>Also - will I get any discernable increase in power from fitting a
sports
>air filter (K & N, Apexi, etc), or is a fatter exhaust the only way to
go?
>cheers
>Paul
>Auckland, New Zealand
>Have you seen our website?.... http://www.vodafone.co.nz
>CAUTION: This correspondence is confidential and intended for the named
>recipient(s) only.
>If you are not the named recipient and receive this correspondence in
>error, you must not copy,
>distribute or take any action in reliance on it and you should delete
it
>from your system and
>notify the sender immediately. Thank you.
>Unless otherwise stated, any views or opinions expressed are solely
those
>of the author and do
>not represent those of Vodafone New Zealand Limited.
>21 Pitt Street, Private Bag 92161, Auckland, 1020, New Zealand
>Telephone + 64 9 357 5100
>Facsimile + 64 9 377 0962
_________________________________________________________________
zQz:
http://photos.msn.com/support/worldwide.aspx
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
ADVERTISEMENT
zZz.
CAUTION: This correspondence is confidential and intended for the named recipient(s) only.
If you are not the named recipient and receive this correspondence in error, you must not copy,
distribute or take any action in reliance on it and you should delete it from your system and
Unless otherwise stated, any views or opinions expressed are solely those of the author and do
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
2.5" exhaust
than flat filter.
cheers
Paul
"Josh Colombo"
irage.com> cc:
02/05/2002
14:54
Please respond
to
BC-BFLegacyWor
ks
can be found here
Hope that helps.
Josh Colombo
exhaust.
the
back.
Ian
>Hello
Japanese
factory
I
to
took
sports
go?
>cheers
>Paul
>recipient(s) only.
it
those
zQz:
ADVERTISEMENT
zZz.
Buy Stock for $4
and no minimums.
FREE Money 2002.
