Fule pump discussion
Posted: Tue Jul 16, 2002 1:40 am
Interesting topic this fuel pump discussion.
> Racing a 92 Legacy Turbo, and the last race (Canadian Rally - Big Horn
> Alberta) had us fighting a nasty intermittent ignition/fuel problem that
> caused no end of grief during the services, but only affected the car once
> on course costing 30 sec. We also ended up warping the passenger side
> manifold (again), causing a large exhaust leak between manifold and the up
> pipe (stuffed it with folded metal, used heat shield to hold it place).
> We still did very well, but I was at a loss to know what was happening.
> The previous owners indicated they had a similar problem and when they
> replaced the fuel pump the problem went away.
> We are running VP race fuel (103 unleaded) mixed with 92 pump gas (40/60).
> Boost was controlled by a controller I built similar to the one on
> Autospeed.com. Worked very well, the initial spike went to 17 psi then
> back to 14 psi. This actually worked very well, but I am guessing the car
> was leaning out since the heat is warping the manifold. No other signs of
> leaning out -plugs were a little carboned even. Car showed no signs of
> detonation while running - but the warped manifolds. Within the rules,
> fuel system is open, so upgrading the pump and injectors would be no
> problem - problem is we can't run an intercooler. We are also cursed with
> a 32 mm restrictor - car was an absolute rocket without the restrictor
> during testing - easily as fast as a stock WRX - or so it seemed. The
> boost controller worked awesome, and the spool up was fantastic!
> Restrictor turned into a dog - just too much weight for the power
> available.
> Knowing all this, what would you guys suggest as an upgrade? Ideally,
> Subaru sourced part numbers would be great (STI) or the overseas RS pump,
> just for ease of install. Do you think this would be enough, or does the
> Holley / Aeromotive FPR the only way to go? The car is less and less
> competitive at events in production-4 against the newer WRX's in the same
> class (we still beat some of them though!) - so we don't want to throw too
> much money at it.
> Any suggestions would be most helpful.
> Rabin Rutten-James
> ISC Help Desk
> Phone: (9)798-8000 or 8-8000
> Fax: (306)787-4617
> <mailto:rabin.rutten-james@isc-online.ca> rabin.rutten-james@isc-online.ca
> available.
> much money at it.
> Rabin Rutten-James
> ISC Help Desk
> Fax: (306)787-4617
