Cooling Fans
Posted: Fri Jan 30, 2004 3:16 am
ok...i'm not too great when it comes to electronics... I have a cooling fan question...I picked up a used MAIN FAN from the junkyard today... this might be a good one for vrg3...
If my assumptions are correct, there are two positive (+) and one negative (-) wire for each cooling fan...
I have the stock driver's side fan (3-wires) that i got from the junkyard hooked up as the MAIN FAN, and i have an aftermarket (2-wire) fan hooked up as the SUB FAN...
When hooking up the aftermarket fan, i hooked up the black negative (-) wire and the green positive (+) wire, leaving the last blue positive (+) wire disconnected.
With the above setup, the MAIN FAN always runs in ACC and ON...and...
the SUB fan always runs when the key is in the ON position
(pressing the AC button doesn't have any effect on the fans)
The setup i had before i picked up the new MAIN FAN today worked with two aftermarket fans with 2-wires...
With this setup, the MAIN FAN would run at all times in ACC and ON...and...
the SUB FAN would only run while the key was in the ON position and the AC on like it is supposed to.
This setup worked fairly well for me, even though the MAIN FAN was always on when its not supposed to be.....but since i got my hands on a stock MAIN FAN, i decided to put it in.
would a setup with a stock fan and an aftermarket 2-wire one cause any electrical changes that would cause them to run all the time?
maybe the wiring diagram could tell someone who actually knows how to read them...i've tried, but i don't see it....
The only thing that i could think of that would cause both fans to run all the time would be a faulty coolant temp sensor; but both a "D-check" and a "read memory" came up with no codes, and the resistance of the sensor is fine...
sorry for being so complex, i hope someone will be able to explain it to me.
Andrew
Andrew
