Help me find Rod Lengths please
ciper
Post by ciper »
Specifically EJ22T EJ20T EJ25 (both versions) and EJ257.
Im looking as well, but I thought you guys could help get the info faster. If you find conflicting info please post it too, so we can work it all out.
Here is some of the info, Id assume its all correct? http://www.wrxworld.com/iclub/engineconfig.jpg
It looks like everything we would ever need, and helps me to get 2.33L displacement like I wanted to start with! (which screws all my flow calculations and turbo choices :roll: )
I found lots of conflicting information!
http://www.ariaspistons.com/sportsub.htm :
EJ205: 5.137
EJ25 Phase I: 5.137 also
EJ25 Phase II: 5.167
http://www.rpmrons.com/WisecoSubaru.html :
all EJ20: 5.137
http://www.jepistons.com/pdf/2002-sport ... subaru.pdf :
EJ205: 5.135
EJ25 Phase I: 5.135
EJ25 Phase II: 5.165
http://www.pauter.com/subaru.htm :
EJ20: 5.135
EJ22: 5.135
EJ25 Phase I: 5.180
EJ25 Phase II: 5.180
http://forums.nasioc.com/forums/showthread/t-40362.html:
EJ20: 5.1378
EJ22: 5.1378
EJ25: 5.1850
Tangentially relevant information:
Mike Shields says the EJ18 con rods are the same as the RA series of EJ20 motors (Source: http://www.spdusa.com/turbos.htm)
ciper
Post by ciper »
