rev stumbling and exhaust pops
Posted: Tue Mar 30, 2004 8:50 pm
by georryan
Well here I thought I was being thorough and fixing things gradually. I did the 02 sensor, new plugs, and was still scratching my head on how I'd get hesitation and what not. I also cleaned my ground points and the battery terminals. Still didn't help at all. Then I did a more thorough inspection of my vacuum lines, and the hose to the underside of my underhood resonator is busted off. I can't believe I never saw that. So after I fix that, I'm hoping I'll get it back to were it is sapposed to be as far as hesitations, and rev stumbling.
Posted: Wed Mar 31, 2004 12:07 am
by TheSubaruJunkie
Ive noticed that my car will buck alittle but only when i get on at WOT. If i back off the throttle, it seems to solve the missfire until i can gain enough speed to use WOT.
On the old subie engines you could use Carb cleaner to find vacuum leaks... i wonder if that'll work on the EJ's as well.
-Brian
Posted: Wed Mar 31, 2004 5:00 am
by THAWA
Hehe, you check your wires? If you want you can borrow my magnecors for a test run when they get here to see if they cure it.
Posted: Wed Mar 31, 2004 5:53 am
by Kelly
Be careful with carb cleaner, it will ruin old, dry rubber.
Werd.
Posted: Wed Mar 31, 2004 11:34 pm
by georryan
I've got new wires, if that was directed at me.
