Is this a good price and a reasonable swap
Posted: Mon May 10, 2004 10:00 pm
by bignose
My 94 legacy turbo wagon 4EAT is slipping pretty horribly in fourth.. A friend has a 5MT from a 2000 2.5 Rs he's willing to sell me.
How does this sound
60,000km's [non abused]
Transmission, shift linkage, 4.11 LSD , flywheel and clutch
and he's willing to deliver it 1800km's sicne he's making a trip home anyways.
1200$ canadian.
That would leave my shopping list down to pedal box, interior parts , master cylinder and driveshaft.
Is this a reasonalble price and a good swap considering it looks like i need a new tranny/rebuild anyways.
Thanks.
Posted: Mon May 10, 2004 10:02 pm
by THAWA
ask him for the rear half shafts, cause you're gunna need em, personally I'd try to find a turbo tranny, but that's just me.
Posted: Mon May 10, 2004 10:30 pm
by bignose
I'm in a geographical location where lots of parts aren't easy to come by. Thus making this very attractive.
I basically just want to know if this is a POOR price or not.
Posted: Mon May 10, 2004 11:19 pm
by THAWA
well considering what you're getting that's an excellent price. But you're gunna need the halfshafts
Posted: Mon May 10, 2004 11:23 pm
by bignose
stupid question, but half shafts would be the bits that drive the front wheels ?
Posted: Mon May 10, 2004 11:33 pm
by mTk
front and rear wheels (AWD)
MK
Posted: Mon May 10, 2004 11:56 pm
by bignose
so for this swap would i need both front and rear ? is the 5mt narrower than a 4eat or something ?
Posted: Tue May 11, 2004 12:00 am
by THAWA
just rear I assume. That better be all otherwise I might be screwed myself :\
The reason you need the rear halfshafts is our differential has the stubs sitcking out from it which the halfshafts slide into, whereas the rs's have the stubs sticking out from the halfshafts and slide into the differential.
Posted: Tue May 11, 2004 1:54 am
by QuickDrive
I wish I could help you here Bignose. I know where there is a 4eat with 150,000kms on it, but like you said, since the parts for our cars are rare around here I'm sorta keeping it under wraps for the unfortunate time that mine dies.
Posted: Tue May 11, 2004 2:25 am
by DLC
I can tell you that the front axles on the turbo 4EAT are the same as the 5MT.
I think you should just be concerned about the rear. You could have someone swap out the gears in your existing diff, if it's compatible, and keep the existing pumpkin and halfshafts. The price would probably be similar and be less labor as well.
Good luck
Posted: Tue May 18, 2004 1:29 am
by Paisan
You will ALSO need the cross member from a 5MT and some other parts IIRC. Look at smallcar.com for the SVX swap and pretty much copy what parts you'll need for that for your car.
-mike
